HELP! sub isnt working(fixed)
Old Dec 11, 2008 | 06:04 AM
Cinderblock's Avatar
Default HELP! sub isnt working(fixed)
ok, i have an alpine cda 9884 HU, a profile 1000 amp and an alpine 12 type e. the amp is 310w rms at 4 ohms so its the right choice im not asking that. my HU has an rca output for a sub so im running that to my amp, like the HU owners manual says. i turn on the power, my Hu turns on, and the amp powers up, but theirs nothing coming from the sub. the wiring, amp, and rca's are all brand new tonight. the sub is used, and my hu is only a few months old. WTF?! is up? plz guys, i was so excited, and i was till about 10 trying to get this to work, and ive got a major cold already lol.
Old Dec 11, 2008 | 06:11 AM
SVicksTC's Avatar
Well the amp is powering on so it is not a fuse problem, have you taken the sub out of the box and looked for loose wires...Was it working before, or is this the first time you tried to install it?
Pull the sub out and directly put it to the amp and see if the sub gets power if it does it might have been loose in the box if you dont get anything out of the sub idk ha
edit: re-reading your post it sounds like this is your first install? If i am wrong dont take offense, but maybe go back and check over your intstall/wires
Old Dec 11, 2008 | 06:43 AM
ya first install, i pulled the sub out already, the wires were tight i guess, the connections on the subs are some kind of spring loaded thing and the wire is tight in their. i have a second sub, maybe ill wire it and see, but i took an amp meter set to watts and checked the amp output for the sub and it wasnt reading anything, am i just not getting any input from my Hu? thanks for the help
Old Dec 11, 2008 | 05:44 PM
anybody else? im stumped. i guess it could be my rca's or the rca output on my deck, but that should work, and those cable are brand new.
Old Dec 21, 2008 | 11:24 PM
norris_l_duckett's Avatar
what are your hd unit setting for he sub ie. are the y to high a rang for you sub range check input setting of hd unit!!!! manufatcture setting opions for the head rca out put good luck!!!
Old Dec 22, 2008 | 12:00 AM
dont worry about it man, i fixed it lol, thanks anyway, their was a little tiny switch under the head unit on the back on the a showing part of the circuit, flicked that and it started working.
xBSciontist
Jun 18, 2019 03:06 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
meowtc
Jan 3, 2015 05:19 AM
Pkupman_77
Dec 30, 2014 09:10 PM
