looking for xA interior led guide
Old Nov 10, 2007 | 10:40 PM
zippox's Avatar
Default looking for xA interior led guide
Hello all. Ive been searching for about an hour or so and will continue to do so but I am looking for a decent guide to install led's in my 06 xa (by pedals, under front and back of passenger and driver seat). I guess my final goal is to be able to either have the led's only on when headlights are on or by a switch somehow. any help is appreciated.
Old Nov 10, 2007 | 11:32 PM
burstaneurysm's Avatar
Just search for footwell cathodes or something like that. Basically all you'd really have to do is either tap a 12v source in the cabin, or run a wire through the firewall to the battery. You're probably best having it on an independent switch.
Old Nov 11, 2007 | 03:32 AM
zippox's Avatar
thanks for the advice, ill be searching
Old Nov 11, 2007 | 04:03 AM
SanchezHacker's Avatar
Here is a guide that helped me when I installed my cathodes. https://www.scionlife.com/forums/viewtopic.php?t=29238 What you need is to get a "Mini Add-a-Circuit" that plugs into your fuse box and gives you a fused 12volts to use. Now with cathodes you don't need to do much after this but with LEDs you'll need to add resistors to each LED and find a way to mount them. Let me know if you need anymore info.
Old Nov 11, 2007 | 04:08 AM
bBlover's Avatar
wait, you have the Scion ones?
Old Nov 11, 2007 | 07:25 PM
zippox's Avatar
ok, so heres my very low intelligence at work and a small diagram i put together to see where i am going wrong
what am i missing/need?
Old Nov 12, 2007 | 04:18 AM
Oznium_com's Avatar
Read this for good info: http://www.oznium.com/forum/topic11823
And about your question of adding more "converters" to the same power wire, read this: http://www.oznium.com/forum/topic8319
Old Nov 12, 2007 | 06:15 AM
zippox's Avatar
i figured it all out i believe thanks to Sanchez. heres the diagram we came up with
Old Nov 12, 2007 | 06:26 AM
Dispatcher138's Avatar
Get the flexible LED's so you dont have to worry about the the converter bull____
Old Nov 12, 2007 | 03:06 PM
zippox's Avatar
I already placed my order at www.oznium.com and i would actually rather have the cathodes. Should be a fun install!
Old Nov 12, 2007 | 03:09 PM
randode's Avatar
Wagonistas
or just buy my plug and play kit.
http://randode.com/store/product0.html
Old Nov 17, 2007 | 10:46 PM
zippox's Avatar
dear god, it took such a long time to install... but it looks nice. ill take pictures soon. www.oznium.com is where its at.
Old Nov 18, 2007 | 06:31 AM
zippox's Avatar
airmankevin1
Feb 14, 2018 01:23 PM
YooItsJay
Dec 2, 2015 08:13 AM
XB06
May 30, 2015 02:42 AM
tc_Jake
Dec 31, 2014 01:45 AM
sithscripter
9
Sep 26, 2003 05:27 AM
