Mounting Interior Neon Lighting?
Old Aug 20, 2005 | 06:06 PM
Bobby_Lee's Avatar
Ronin Scion
Quote from Randode's sight:
Cold Cathode Interior Lighting xA/xB
Mounts under dash and under front seats. Ten times brighter than the dealer installed LED lighting. Includes four 12" cold cathode lights, wiring harness, OEM style switch, mounting ties, and detailed instructions. No drilling or cutting required. Easy two wire hookup. Available in red, white, blue, green, and now HOT LAVA! Don't be fooled by cheap imitations. Randode was the first to design and build a cold cathode lighting kit for automotive use!
$100.00
$100!?!? are you serious? i could do that same setup for no more than $20. Sure it may be an "easy" installation, but i doubt that its worth the extra $80 that you'd be paying... oh and "first to design and build a cathode kit for automotive use"??? i've been installing cathodes in my cars for the last 2-3 years, and i'm absolutly positive that people have been doing long before that.
Old Aug 20, 2005 | 07:43 PM
PRE5TON's Avatar
we can fight elsewhere guys - anybody able to help?
Randy: You got my full support with the kit - everybody that i know that has one, loves it. -- see you tonight
Old Aug 21, 2005 | 02:42 AM
tbone587's Avatar
Well the neons got delivered today from oznium. The install was very simple and the lights work great. If anyone needs any help I would be glad to offer some assistance.
Old Aug 21, 2005 | 04:17 AM
PRE5TON's Avatar
Where does everyone suggest to ground the cathodes to? Also, do i need the add-a-circuit for mini fuses or the normal one? Do i need to buy 2 add-a-circuits or just one if i'm going to wire cathodes for the front and back? Would i still use a 3 amp fuse for both the front and back in one add-a-circuit?
Old Aug 21, 2005 | 09:39 AM
Oznium_com's Avatar
You can ground to some metal under the dash maybe. You could do it ghetto and wrap a long piece of stripped wire around some hole, or maybe drill a hole somewhere and use a self tapping screw to screw down an o-ring with the wire crimped on
You probably need it for mini-fuses
3 amp should be find for front and back
just 1 add a circuit is fine
Any questions during the install gimme a call and if I am around I will try to help!
800-245-8131
or my cell: 925-683-1839
Old Aug 21, 2005 | 04:15 PM
PRE5TON's Avatar
800-245-8131
:D I LOVE SITE SPONSERS! Thanks a lot. I'll let you know how it goes
Old Aug 21, 2005 | 05:17 PM
randode's Avatar
Wagonistas
$100.00
you get what you pay for. if you are comfortable with building your own kit, thats fine. i'm all about the diy (i wrote the how to on scionlife!). but if you dont know how, or dont want to deal with it, then buy my kit. you are paying for convenience.
you can make a sandwich for a few cents, or you can go to subway and spend $5 on one. its the same thing.
Old Aug 21, 2005 | 06:41 PM
PRE5TON's Avatar
$100.00
WORD!
Old Aug 21, 2005 | 06:43 PM
PRE5TON's Avatar
how is it that: best but, circuit city, ultimate electronics, autozone, nappa, home depot, lowes, or the local hardware store - NONE carry the add-a-circuit for mini fuses....so frustrating!
Old Aug 21, 2005 | 06:55 PM
chadfo's Avatar
http://www.partsexpress.com/pe/showd...number=071-585
Old Aug 21, 2005 | 08:09 PM
PRE5TON's Avatar
they want $18 shipped = no way
Old Aug 22, 2005 | 02:05 AM
tbone587's Avatar
I got the mini add a circuits from autozone.. They should carry them
Old Aug 22, 2005 | 03:12 AM
PRE5TON's Avatar
i called three of them around me and none had it. I just ordered it off of amazon for $15.00 new..
Old Aug 22, 2005 | 04:38 AM
Oznium_com's Avatar
It seems crazy to spend that much on an "add a circuit".
You could get the same results and spend ZERO on it...
Tap into the back of the cig lighter, or tap into the fuse block directly
Old Aug 22, 2005 | 05:27 AM
2k5_BOP_xB's Avatar
Or, you could just buy my kit. its plug and play. Detailed instructions are included. Since I was the first one to put cathodes in a Scion.
Buy Randy's CCFL, they are great and he is really helpful!
Old Aug 22, 2005 | 05:37 AM
2k5_BOP_xB's Avatar
Originally Posted by Tekviper
Wow didnt know to give advice you half to plug Scion life members products .
I ll keep this in mind when people ask for help.
-Tek
So what is the problem with putting in a plug for your own product, especially if it is a great one?
Besides, the word you want to use is "HAVE" not "HALF".
Here I will use it in a sentence for you.
I think you Tek, HAVE half a brain.
Old Aug 23, 2005 | 12:55 AM
Bobby_Lee's Avatar
Ronin Scion
That does make sense... whether its worth 80 or so dollars is another thing. Also, i'd just like to point out that most people here are car enthusiasts, and along with that, enjoy doing their own work to their cars. Sure installing and wiring cathodes yourself may not be convenient if you aren't completely knowledgeable on the subject, however, it is a great and simple way of learning. I'll admit that i started out by just getting a cig. plug splitter and just hooking them up that way, but through trial and error i've learned how to do proffessional, clean installs. In my opinion, learning how to wire simple things like cathodes will better you further down the road...
Old Aug 24, 2006 | 04:23 AM
ignatiusaids0o's Avatar
Default LED xb Installation
I know this has been discussed already!
One question.
If i purchase the LED lights from scionpartspeople.com will i be able to install them without help and no previous knowledge of electrical work???
One question.
XB06
May 30, 2015 02:42 AM
toyotaisme
Jan 10, 2015 10:24 PM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
sithscripter
9
Sep 26, 2003 05:27 AM
