Are OEM xB Fogs Plug & Play?
Old May 6, 2007 | 10:08 PM
05_JDM_bB's Avatar
Default Are OEM xB Fogs Plug & Play?
Are the stock OEM xB fogs Plug and Play? I never got Fog Lights for my xB when I had bought it so I was just wondering if it would be an easy install?
For those who had purchased them separately, do I need to purchase anything else? Switch? Harness?
Any help is greatly appreciated! Thanks for looking.
__________________
Old May 6, 2007 | 10:16 PM
DriverXa's Avatar
The factory kit is all just plug-n-play. Most of the wiring is there already form the factory. The kit comes with the lights, switch , and I believe the relay as well. Just follow the instructions n enjoy.
Old May 6, 2007 | 11:24 PM
richardhay's Avatar
Default Re: Are OEM xB fogs plug & play?
They are plug and play. The most difficult step is installing the relay behind you fuse panel (which is more frustrating and time consuming than difficult). With some patience, you should be able to do the install easily. The steps are:
1. Remove the fog covers.
2. Install the lights and plug in the existing power connection.
3. Install the switch in the dash and plug in the existing connection wire that is behind the dash.
4. Install the relay.
I hope that this helps!
Richard
Old May 7, 2007 | 02:32 AM
ItsmeJSB's Avatar
Installed Fogs a few weeks ago ... "popped" out the blank fog hole covers, popped in the lights ... booklet was easy to follow. Relay and switch just plug in too. VERY easy. They don't add much to the front end though. The lenses are a "frosted" glass type, not completely clear. I am happy with them overall. Look best at night with low beams on too - no fog needed to brighten things up ! lol
Old May 7, 2007 | 05:50 AM
05_JDM_bB's Avatar
Thank you all for the quick responses. Appreciate it!
Old May 7, 2007 | 05:54 AM
OldYeller's Avatar
Save those fog light blanks after you remove. People are always trying to find them......
nolakpd504
Scion tC 2G Aero & Exterior
9
Mar 25, 2013 04:18 PM
Sunny
9
Nov 15, 2008 09:04 PM
racingbrian
Sep 14, 2006 12:51 AM
NBtC06
Scion tC 1G Aero & Exterior
Mar 21, 2006 02:59 AM
superbiker
Feb 23, 2006 01:19 PM
