Reverse Wire
I did search and know where is at. 9 Pin Plug black/red wire.
but can anyone give me some tip how u guys squeeze ur hand up there and tap to it?? All I can do use get 1 hand in that spot. Any suggestion would be great
Thanks!!
Thanks!!
I tapped the reverse wire for mine at the fuse box. It is a little tricky to tap the wire, but If you unplug the harness from the fusebox, it makes it a little easier to splice in.. Also, if you feel like running a wire all the way into the hatch area, you can tap it directly at the tailight..
XB06
15
Oct 1, 2022 10:24 PM
MadSciontist_xB
May 10, 2015 06:28 PM
JcBgOe
Mar 16, 2015 12:57 PM
