running wire tips????
Old Feb 18, 2006 | 02:04 PM
SoCalMike's Avatar
Default running wire tips????
Ok Guys.... I just checked the "Tech" section out and could not find anything on "How to run wires in the XB" I know how to hook up the amps I am only looking for which way to run the wires, Anyone???? My plan is both 2 and 4 ch amps under seats. Thanks!!!!
Old Feb 18, 2006 | 03:19 PM
tbone587's Avatar
The easiest way is to run it through the rubber grommet on the driver side. u can fit some pretty large wires through that. I have also ran power wire through the passenger side grommet, but thats a little more difficult because there is obstructions inside the car. On the driver side grommet, its littler straight into the car and there is nothing in the way.
Old Feb 18, 2006 | 08:03 PM
FoDoToaster's Avatar
If you've got an automatic, you can drill a hole where the clutch would have gone through the firewall. If thats not an option, look at the wire grommet just left of center on you firewall from outside. You'll see two little "nipples" on either side of the wires. Punch a hole or cut the ends off. You can use a wire puller or whatever to feed the wire through. They will end up on the passenger side inside the car. Just because of using anything hard/sharp/metal. Those are important wires.
Old Feb 18, 2006 | 11:01 PM
bB2NER's Avatar
Music City Scions
If they are going under the seats I'd try running the power wires through the drain holes in the front floorboards then under the carpet right to the amps.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
TheSilencerTC
Scion tC 2G ICE & Interior
Feb 24, 2015 04:56 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
bryanrx7
Jan 1, 2004 09:53 PM
