which silverstar should i get
Old Sep 19, 2005 | 05:54 AM
hippo's Avatar
Default which silverstar should i get
i dont know the difference what should i get.
SilverStar 9006ST
http://www.amazon.com/exec/obidos/tg...otive&v=glance
or this one
SilverStar 9006XSST
http://www.amazon.com/exec/obidos/tg...otive&v=glance[/url]
Old Sep 19, 2005 | 04:22 PM
2005ScionTC's Avatar
They both put out the same amount of light. The difference is the base ST is a 90 angle and the XSST is straight down. I had to use the XSST in my LHS but the ST work in the tC.
Old Sep 21, 2005 | 12:59 AM
hippo's Avatar
"low beam applications for four-headlight systems, two on each side or in some cases as a fog light (maximum 60W). "
so if i buy 4 silverstar bulbs, 2 for each side it increases to 60w, would that burn the wires by any chance?
Old Sep 21, 2005 | 09:18 AM
leonDB's Avatar
Um... huh? Are you talking about the high beams? Those are 9005. I don't think you can fit two 9006 bulbs on each side.
I haven't seen silverstars burn wires, but I have seen them burn prematurely a few times. I don't suggest them, because they're overpriced and don't look that great. The blue luminics is nice, and so is Thunder Gp 7500k bulbs. I've had my GP for around 6-7 months now, now premature burnouts and no wire probs.
Old Sep 21, 2005 | 12:39 PM
ack154's Avatar
You would buy 2 9006ST for low beams and 2 9005ST for high beams.
If you have the fogs, you would buy ANOTHER 2 9006ST.
And they would have ZERO problems with your wires. I'm not sure where you got that "increases to 60" part...
Old Sep 21, 2005 | 04:31 PM
hippo's Avatar
when i have lowbeams on 2 light bulbs on each side bright up, one behind the silver thing and the other below that bulb pointing up.
Old Sep 21, 2005 | 05:13 PM
z-lite's Avatar
The bottom light is known as accent light, the top one is obviously your low beams.
Old Sep 21, 2005 | 05:52 PM
stl_tc_king's Avatar
go for the luminics bulbs. i have had both and prefer the luminics.
RCFelix
Scion tC 1G Aero & Exterior
Feb 4, 2006 01:43 PM
tcmann
Scion tC 1G ICE & Interior
31
Dec 31, 2005 12:42 PM
fm_tc_cruizer
Nov 8, 2005 05:31 AM
7thgear
23
Oct 14, 2005 05:10 AM
xmetalx
Mar 24, 2005 06:18 AM
