Vent LED Install
Originally Posted by TheScionicMan
LED DIY:
select location, drill hole, insert grommet from front of hole, insert LED in back of hole until it seats in grommet. Ground neg, connect all positives together (assuming multiple LEDs) and run to your switch, then to your power source. Done.
I would also suggest using inverted tip LEDs in the vents.
Most of my lighting is connected to a switch. My 5 cupholder LEDs are wired into the shift indicator light on the shift console, the normal mood lighting is on one switch and the show lights are on another
I might do the VIP open-door treatment in white.
Switches are key, I have 6 of them:
-underseat/dash cathodes
-dash/AC lights
-door/roof handles
-exterior lights
-cupholder/seatback hooks
-glovebox/ashtray/dash box
They are all hooked up now! I love it! I just went cruising around for a while. Oh and if anyone else is going to install led's in their car don't use superglue to hold anything electrical in place. I did that and almost set my car on fire.
I had put one in each vent, one in each door opener, and one in each door closer ( the thing you put your hand in to pull it shut. But i disconnected the vent ones and I am going to put a new set in there without the super glue this time. I guess I could just use ducktape. So hopefully that will work then.
Originally Posted by Pimpe_Ok
Thanks for chating with me by the way.
yea u got any pix of yur final install?
The way I did my vents by the doors was I took of the center console and then took out the head unit and the 3 screws around it...one to the left one above and one to the right. With those out I took off the speaker covers about the left and right vent and unscrewed the speaker, drilled a hole in the vent at an angle. For the wiring of those LED's I pulled the dash up slightly on the frond just enough so i could pass the wire down and run it underneath and run them to the center console area. If you need more details let me know.
I put them in both of the handles on all the doors...as for the ones that you pull it shut with I have them shining to the front of the car...EX:
IIIIII
I I
I I
I I
I + I
ILEDI
IIIIII
this is the driver side door handle to close the door I put the LED on
the back edge and have it shining the direction of the "+"
Sorry that is the best i can do description wise but once I find out how to put pics oh here I can just show you the pics....Hope this helps though. Let me know if you need anything else
Anyway "FeeLTHeBuRN" thank u for your input bud... i got the hole point thats exactly what i was going to do just was not shure of were to put the led but i was thinking there to. good place dose not get in the way.... i think i am just going to take the hole top dash off its only in there with 7 screws and there is a realy good DIY on the tech. section of this site i need to do it so i can put in the ones that will go under the top dash to light up the shelf above are glove box. i will show u waht i mean when i get it done this weekend. i think u might like the shelf lighted up. i will do it so u cant see the LED eather i am thinking of using a 11mm tubing to mack my own led holders so i dont have to just put the Led all sticking out like. Peac for now.....
IIIIIIIIII
I..............I
I..............I
I..............I
I..............I
I..............I
I..............I
I..............I
I..............I
I..............I
I...LED....I
IIIIIIIIII
^^^^^^^ thats waht u ment to do right??
IIIIIIIIII
I..............I
I..............I
I..............I
I..............I
I..............I
I..............I
I..............I
I..............I
I..............I
I...LED....I
IIIIIIIIII
Yea that's what I meant and that is the way it was when i typed it in without all the periods i just used spaces and for some reason it always crunched it so. I just left it as is.
Would you please put the link to the DIY. I have tried searching and can not find it. I have eight lights that I would like to put in my vents. For my RS 2.0. I am getting all of the inside mods done first before I start on the Major outside ones.
