Water on the floor in the back seat.
#41
Well our boxes just seem to like getting Wet. I guess I'm going to have to get one of those SexBox stickers now.
Contrary to some belief my leak appears to be solved by cleaning out my fenders.
I haven't been running my ac for awhile but I didn't use it much in the summer either. I have checked the condesation drain and it was fine, it was draining regularly.
I know it sounds crazy but pulling back the wheel well liner and cleaning out the crap worked for me.
Good luck to the rest of ya swimming at 65mph.
#42
Originally Posted by BoxinBuzz
... my leak appears to be solved by cleaning out my fenders... pulling back the wheel well liner and cleaning out the crap worked for me...
So you pull on the liner to get behind it, rather than remove the liner?
How can crap get behind the liner?
How does water from behind the liner get inside the car?
#43
Originally Posted by vintage42
Could you describe how to do this in more detail?
*easier to do if you jack the car up and let the tire hang down some
after removing the retaining clips you can pull the liner down and get to the area behind it while not completely removing it.
crap gets behind the liner from stuff falling ontop of the car between the windshield and hood... remove the wipers and a few more retainers to pull it out main culprit is pine needles and small leaves.
as for how does the water get into the car... i'm still working on that
#45
Re: Water on the floor in the back seat.
Has anyone else noticed this? For about a month now when it rains I've noticed a good amount of water on the drivers side floor in the back....
https://www.scionlife.com/forums/vie...ht=water+floor
#46
same problem
I have the same issue except it's on the passenger side for the most part. Seems to be leaking through the panoramic sunroof but not for sure since it is traveling through the car and not not actually dripping. I already fixed where there was a clog up front and it seems to have stopped.
I had in-channel rain guards, thinking they might be pushing out the weather stripping I removed them. Yesterday the floor was bone dry. Today, soaked, there was nothing wet besides the floor.
Can anyone help?
Can anyone help?
#47
Water on the floor is not going to come from loose to clogged moonroof drains unless it drips from the ceiling. And then it would drip from the corners of the moonroof gutter.
#48
Most definitely sunroof drains. They run through the interior of the car to get to the bottom exterior of the car. Somewhere along those lines is a clog and the water has to go somewhere so it empty I to floor board. The rear floor board I'm still researching because cleaning the sun roof drains solved the front but now the passenger rear is flooded. I'm going to pull the finder but I think since a panoramic sunroof that there is drains at the back of it to I will keep you updated.
#49
If a tube gets plugged, the gutter overflows and water drips from the ceiling.
If a tube comes loose from its connection on the gutter, water again drips from the ceiling.
Water from the gutter or a disconnected drain tube does not empty to the floor; it must drip from the ceiling to the floor.
The xB in this video has the same power moonroof as mine did, and the drains are shown in the first couple of minutes:
#50
Scion tC 2011, kinda same problem
Ive got the rear passenger footwell fully soaked and rear driver footwell sometimes partially soaked.
It’s not the AC stuff as this is in front of the car. I’ve seen that we don’t have sunroof drains on our cars.
Anyone know what might solve this issue? Can people who have solved their wet issues reply with any pictures or say how they’ve solved this??
#51
my dr floor was getting wet so I pulled the back seat bottom and trunk stuff out to look for moisture and I found some but it wasn't obvious where it came from. So I took a watercolor pencil and made drew lines all over the place to show when it gets wet. The culprit was the screw hole that mounts the side trunk panels. The pocket for the screw ends in the outer wheel well and the end had opened up. Some rubberized undercoating in the wheel well fixed that. When I stripped the interior for sound deadening install I found several drain plugs in the floor that have become loose fitting over the years, sealed them up with undercoat as well before I laid down the butyl mat as a precautionary measure.
emason78
16
12-27-2019 04:43 PM
dmpsk8
11-29-2011 12:58 AM
lhtheman
11
11-30-2006 08:27 PM
