Where to get interior lights
Old Feb 23, 2005 | 07:06 PM
markd's Avatar
Default Where to get interior lights
I have checked ebay and randoe.com I am looking for the interior lights that go around the cup holder. Cant see to find them. Anyone know where I can get these.
Thanks!
Peace,
MD
Old Feb 23, 2005 | 07:11 PM
DJ_X_Trodinaire's Avatar
like the options?
they are LEDs
Old Feb 23, 2005 | 07:14 PM
markd's Avatar
yeah the ones that they install at the dealer
Old Feb 23, 2005 | 07:19 PM
unlmtdndeavor's Avatar
thats custom man. drill a hole in the bottom of the cup holder and install a LED. thats how its done at the dealer i believe...and its cheap..like 50 cents
Old Feb 23, 2005 | 07:36 PM
markd's Avatar
how do you wire up an led. all the ones that I am finding off of google are actual bulbs that you screw in to a socket. Is there a certin type of LED that I need to search for.
Sorry if this question seems stupid I have never messed with interior lights at all.
Old Feb 23, 2005 | 07:47 PM
stick_1NZ's Avatar
I used the VARAD LED's, there's 4 LED's per set. I drilled a hole on the bottom of the cupholders where it's not visible to anyone, about the size of the LED bulb. You can probably get them here:
http://cgi.ebay.com/ebaymotors/ws/eB...category=33713
you may check out my interior here:
https://www.scionlife.com/?stick%20xB
Old Feb 23, 2005 | 07:59 PM
markd's Avatar
ok I see. now another question
I have the interior cathode lights hooked up. I have 4 different sets. 1 set under each seat. Can I hook all of the cathode and leds to the same power wire so I can have them all on one switch. Dont know if that would be too much for the fuse slot to hold.
I have a 3 amp fuse in the box and then a 30 amp on the inline fuse.
Thanks for all of the help people.
MD
Old Feb 23, 2005 | 11:42 PM
TheScionicMan's Avatar
Yes, you can hook them all together.
I bought some LEDs from this guy on eBay and they are great. Well made and ready to wire up...
Old Feb 24, 2005 | 04:44 AM
Max2k's Avatar
You're going to want to point those LEDs toward the front of the cupholder, not up from the bottom so you don't get glare on the windshield.
I use these LEDs for my installs: http://www.autodirectsave.com/LED_lights_wired.asp
Old Feb 24, 2005 | 02:35 PM
markd's Avatar
Cool thanks all for the help. Found some on ebay gonna check Autozone as well though. The shipping on these leds are outrageous on ebay. Dont need that many so I may just buy a kit from Autozone.
Thanks!
Peace,
Mark D
Old Feb 24, 2005 | 07:59 PM
LauderDog's Avatar
Hey Max and co.,
That looks like a good source and a good price for 20 leds...did you get the 5 mm or 10 mm, and what's the dif?
Cant wait to get mine goin. Serious LED envy going on.
Matt
Old Feb 25, 2005 | 02:55 AM
Max2k's Avatar
5mm. They're smaller and easier to stick in those nooks and crannies.
Old Feb 26, 2005 | 01:06 PM
Chimmy3's Avatar
I'm using the 7 color changing evil eyes by lite glow... it comes with its own controller to make it cycle or select colors. you can get it for 20$ for 4 or much cheaper on ebay. my only problem right now is where and how to mount the controller so that it looks oem.. that and how/where to mount the leds in the cupholders.
I'm afraid that if i got with the oem point the leds will protrude too much. I was thinking instead to tuck it in the corner close to the floor and get a clear plastic ring to line bottom with.. that way even without a drink.. the cupholder will light up...
Old Feb 27, 2005 | 03:25 PM
NYYxB's Avatar
Default cup holder led
I got my leds from Varad on ebay. Installed them in the "corners" of each cup holder with the bulb pointing toward each door. I spliced into the light power wire from the automatic shift plug under the console so they are on when the (head)light switch is on. Be careful when manipulating the led itself dont bend the wire at the base of the bulb as it snaps off real easy.
YooItsJay
Dec 2, 2015 08:13 AM
clickclickw00t
Feb 18, 2015 08:57 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
tC6M
Nov 26, 2014 06:44 PM
sithscripter
9
Sep 26, 2003 05:27 AM
