Where is speed sensor wire for xB?
Help me,
I know this has been covered before. Still can't find location.
Posted was back of fuse box 18 pin, purple and white. I looked, and looked, still can't find it.
Installing an Eclipse navigation and I need this hook up.
Can a kind sole help me with better description or a picture.
Thanks in advance.
Thanks in advance.
ubow, the vss wire is used by the gps to adjust the speed and timing of the maps. vss = vehicle speed sensor.
in simple terms, the signal from the wire tells the maps how fast to move, and adjust the timing
Thanks for your help. Found the connection.
It is just very tough to reach under the dash, behind the fuse panel to unplug the connection. You are working blind because you can't see it.
daniinpitt
Apr 4, 2015 08:07 PM
