Window won't go down - Reset electrical?
My passenger side window won't go up or down from either the driverside or passenger side door.
I remember somebody talking about a way to reset something on the car to fix the problem. I tried searching but came up with nothing.
If anyone has the answer, or a link, let me know. THANK YOU!
___
___
Originally Posted by windowtint
you fried the regulator. go to a glass shop or dealer if you still have a warranty.
thank you though, i really appreciate it.
if you unplugged the battery, you have to reset the ecu. Just hold the button up for 10 sec and it should work. If this doesnt work take it to the dealer.
I had to recet the windows when i installed my WR intake
i remember i took the passenger door panel off and the auto up and down stopped working. i took the panel off again to see if the wiring was loose and when i put it all back together it worked again. weird???
Yeah do the normalizing thing . That happened to me when I installed my remote starter in my tC. I freaked but found the solution in the owners manual. That's all . Good luck on that.
If that doesn't work take it to the dealer. Whatever you do, don't reset the battery because you will just make the driver's side window go bad also.
__________________
__________________
When I installed my sterio, and reconnected the negative battery, my passenger switch didn't work for a while, in addition to my sunroof not having the automatic open feature... I had to hold it down.
This happened to me the two times I disconnected the battery, but it worked okay that same day about an hour later.
If it continues not to work, take it to the dealer.
wazzu_coug
Scion tC 1G ICE & Interior
Mar 31, 2008 08:37 PM
hejustlaughs
May 4, 2005 06:45 AM
