Air Ride Sites and Companies for the xB
I am looking for a full Air Ride Setup I can buy that i can put in my xB. Can I get a few sites and insite on if the set-ups the way they are decent and reliable as they are? Please help me out in this area as I am trying to order a set-up in the next couple weeks.
Thanks in Advance!
Thanks in Advance!
Try searching for Air Ride theres lost of post with good info on good and bad about each kit
Everyone is going to tell you there favorite and what they use..
I use Easy Street's Front Air Struts
I have Easy Streets Rear Kit currently but Im switching over to FBI's Rear bags and brackets as soon as they get here from FBI
www.fbimini.com
www.fbimini.com
www.fbimini.com and www.suicidedoors.com for all your air needs. Want to go the cheap and efficiant way, where you will have a good set up and get everything at good prices, they are the ones you wanna go with. Or spend your money on the name of air runner and get basically all the same stuff but struts for more than half of what the same stuff costs.
go with those 2 links, sittin pretti has helped me out a lot. If i ever go with bags i will piece together everything from that site^^
EasyStreet Front Struts - 650$
FBI Rear brackets - 99$
RS52 SlamSpecialties 2500lb bags - 140$~
Viar 450c 100% duty compressor - 200$~
Then of course line, fittings, gauges, valves (40$~), tank prolly some other sheit too i'm forgetting, should be under 1500$ and i'll try to install it myself
oh yea, i'm only going to run a FB setup, haven't found a reason to run FBSS yet
Hey Rebel Man check out www.gravity-werx.com he can get you the front struts from ES a lot cheaper then that If i remember it there around 500
everyone pretty much coverd this up; umm. check my sig, then email me for a .zip of the documents on air if you want to learn about it...
also the tech section has about 6 pages of q&a; its worth reading for a first-timer
Originally Posted by Sittin_Pretti_Box
I really like Viair and such, but they pull a lot of current from your battery and can cause some wiring problems, so when doing it, make sure you use good size gauged wire.
carid
02-09-2015 01:49 PM
Godfryness
01-02-2015 11:18 PM
boxzila
34
01-12-2004 03:27 AM
