DOES CAMBER BECOME A LARGE ISSUE WITH DF210's?
Old May 18, 2006 | 10:39 PM
AleXb's Avatar
Default DOES CAMBER BECOME A LARGE ISSUE WITH DF210's?
Any feedback or comments....
Old May 18, 2006 | 11:07 PM
MattyRattyPoo's Avatar
Your asking if the wheels camber at such a low drp with the DF210's correct?
If so, it won't happen like when you lower a honda. Just get an allignment once you lower it.
Old May 18, 2006 | 11:33 PM
AleXb's Avatar
Awesome, thanks so much for the helpful response.... Judging by the looks of other Xb's with DF210's, it didn't look as if there was a dramatic chnge in camber.
Old May 19, 2006 | 12:09 AM
RTon20s's Avatar
If by dramatic you mean no change, then yes, it is dramatic. I lowered the wife's xB on DF210s a few weeks ago and haven't even had it aligned yet. It tracks straight as an arrow, has no shake at high freeway speeds, and no signs of abnormal tire wear. I'll probably get the alignment checked when we have some extra money to spend, but it isn't a huge priority.
Old May 19, 2006 | 01:02 AM
BrianxB's Avatar
Id be careful with that. After putting my coilovers back on the car tracked straight but the toe was WAY out.
Old May 19, 2006 | 02:47 PM
Prototype_xB's Avatar
Your toe is going to go waaaaay out anytime you remove the front struts. There is no camber adjustments, but there are some endlinks on the market that you can use to adjust the front camber +/- a little over 1 degree. The camber on DF210's are roughly around 1 degree negative all around so nothing to worry about. No abnormal tire wear, etc. HOWEVER, if you run a set of OTG shims out back you gain another degree, which i've learnt that hard way does wear your tread at an angle.
djmike113
Mar 27, 2015 10:50 AM
evolving_machine
Feb 27, 2015 09:53 PM
Miqmiqmiq
Feb 4, 2015 05:05 PM
TheTripleC
Jan 4, 2015 06:46 PM
kleecker
Jan 2, 2015 08:09 PM
