Does the XB springs of tiens fit the XA????
Old Aug 7, 2006 | 04:53 PM
Carlitos's Avatar
Default Does the XB springs of tiens fit the XA????
can someone please help me on this? thanks
Old Aug 7, 2006 | 05:27 PM
JSosa's Avatar
everything on the xB fits the xA, except for body panels and some chassis parts.
Old Aug 7, 2006 | 09:18 PM
Carlitos's Avatar
soo the aftermarket springs fit on an xa even doe there from an xb????
Old Aug 8, 2006 | 02:41 AM
saronian's Avatar
Yes. The xA uses the same aftermarket springs. You can swap from xB to xA and back.
Old Aug 8, 2006 | 11:13 AM
dugzilla's Avatar
You can swap them, but the spring rates for the xA are different than the xB.
Old Aug 8, 2006 | 04:11 PM
saronian's Avatar
The stock spring rates are different between xA & xB but Tein springs are the same rate for xA & xB.
The original question was about Tein springs.
Old Aug 8, 2006 | 04:43 PM
dugzilla's Avatar
the Tein spring rates are the same, but I don't think the springs are the same, the drop is different and the part #'s are different.
Old Aug 8, 2006 | 05:00 PM
saronian's Avatar
That's a very good point. With different part numbers, there could be some difference.
Old Aug 8, 2006 | 07:25 PM
xA_Factor's Avatar
S-Techs: Spring rates are the same, but the rear drop is slightly different. My guess is it's to help to dial out some of the Box's tendency to squat a bit in the rear.
xA = 1.7 front, 1.7 rear
xB = 1.7 front, 1.5 rear
Old Aug 8, 2006 | 07:27 PM
xAScionicle's Avatar
they do swap to each other.
However....
aside from all the good info so far, the xb springs will make the rear sit higher.
I tried a swap of trd rear xa to Tanabe.
the xb was originally much lower than my xa.
with the Tanabe spings in my xa, the rear actually sat higher than with my trd springs.
Tanabe 2.0" drop on xb. on my xa it was about 1.0"
hope this helps
Old Aug 9, 2006 | 02:44 PM
Carlitos's Avatar
thanks guys for some info...soo if I put my tiens in the xa the car might look slanted a lil bit? like a hot rod? or would u even be able to tell?
Brammi
Nov 13, 2016 03:46 AM
ScionDP
Mar 1, 2015 10:57 PM
carid
Feb 12, 2015 11:54 AM
fluxingnation
Dec 26, 2014 04:28 PM
hydrogen
Oct 29, 2003 04:58 AM
