Emergency Brake
I have a 2006 xB. The rear brake pads are new and adjusted. The emergency brake cable is adjusted as tight as possible and it's still not able to hold the vehicle still when in D or R. It failed inspection.
The cable is connected to the levers on the rear brake system. What else could it be?
______________________________
Last edited by MR_LUV; Sep 4, 2018 at 10:28 PM. Reason: Moved to Correct Forum by Administrator
Can you post the resolution to the issue when you find out what it might be? Be nice to have the reference should someone else have the same issue in the future.
fxeditor
Jun 15, 2015 08:56 PM
