Hard right turn = something rubs
Old Oct 14, 2009 | 09:01 PM
rru's Avatar
rru
Default Hard right turn = something rubs
WTF? This my bone stock daily driver '06 XB. Everyday I pull into a parking garage and hear this when I make the hard right through the garage....
Everything on the car is factory. Suspension, tires, wheels...everything.
Anybody have any idea what it is?
http://s10.photobucket.com/albums/a1...1014123902.flv
Old Oct 14, 2009 | 09:49 PM
tCscotty's Avatar
Have you taken the wheel off and checked the shroud on the disc brake to see if it is rubbing on the disc?
Old Oct 14, 2009 | 10:05 PM
jct's Avatar
jct
it does sound like you need to push your brake dust shield back
Old Oct 14, 2009 | 10:09 PM
TCpete's Avatar
how much do you weigh¿?
i keeed lol.... nah srs.. sounds like your brake shield is rubbing the rotor or you might have a rock stuck in the rotor area... take wheel off and inspect the brake system components...
Old Oct 23, 2009 | 07:22 AM
island_box59's Avatar
I have this exact prob..except when I'm making hard left turns and driving regular (the noise comes from the passenger side making left turns). Took it in to the dealership and they took a look at it; jacked it up and checked the tire and rim for the wheel bearing (good); checked the brake pads and caliper and the dust shield (good, too); then they pointed to an area of the axle shaft (they said it might be the axle bearing). Still waiting on the SPO parts to see if they're right. Check yours out as well.
Old Oct 25, 2009 | 03:24 AM
Kuriboh's Avatar
i had the same problem, i was on my enkei 17''....i didnt know what to do, so i got new rims... 15" 501's and problem solved! haha
Old Oct 25, 2009 | 07:37 PM
daneisthegreatest's Avatar
sounds like the dust shield to the caliper rubbing. also, i am quite dizzy now :p
Old Dec 3, 2009 | 04:40 PM
recka808's Avatar
Ronin Scion
I'm having the same problem on my 04. I jacked up checked all componets nothing obstructing dust shield rotor caliper tight. at first i thought a bearing wearing out but then on previous vehicles it would constantly make a humming sound even when driving straight, not just with cornering. i did notice how ever when lifted my ride and car was on drive CV joint was making an audible clickin sound and looked as if had play. i'm assuming i need to change the rack pinion on the old girl. Now i've been hearing a sound from my rear drums; i'm hoping it is just brake pads warning me they need to be changed. It is definatly a constant humming sound so i hope it not a bearing.
Old Dec 3, 2009 | 09:56 PM
jct's Avatar
jct
the wheel bearings will be easy to change out on the rear
Old Dec 5, 2009 | 09:35 AM
hey all, well my prob got fixed with a set of new 17's. LOL! Found out after all the trouble with the dealership and me jacking it up that it was the passenger spokes that were snapped..three to be exact Krazy that I was driving for nearly a year thinking what the heck was the noise Hope if yours is the same as mine that a new set will fix the prob...good luck.
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
meowtc
Mar 5, 2015 02:28 AM
setpol
Feb 17, 2015 11:33 PM
cid_mcdp
Jan 5, 2015 02:45 PM
sensez
9
Dec 29, 2003 06:26 PM
