I need your help guys
Recently I've discovered my xA sits 1/4 of inch lower on driver's side. I dont rember what it was with stock springs. My xA is set up with TRD coils + stock struts/shocks.
Rear sits about the same.
What I have done so far to pintopint the issue.
1. swapped struts RH - LH with no change.
2. Swapped rear RH - LH coils with no change.
3. Loosened up all suspension botls and retorqued them with suspension loaded. No change.
4. rechecked tire pressure (tires are new) no change.
5. no visible damage to struts or suspension components. Subframe looks OK.
So, what Im asking you guys/gals is to help me with some simple measurement to see if its something normal/ubnormal across Scion xA. Please measure LH&RH front-rear (middle of the wheel hub to the lower edge of front fender) and post your findings.
BTW the handling has no ill characheristics. Drives well and tracks well.
Thanks a bunch!
Thanks a bunch!
DjFrOsT
Dec 13, 2003 04:18 AM
DjFrOsT
Nov 6, 2003 04:54 AM
