One Ton Camber Shims
Old Nov 10, 2005 | 03:45 PM
Spider13's Avatar
Default One Ton Camber Shims
I was wondering how far this moves the tire/ wheel out. I specially want to know about the top of the wheel. The website says 3/8, which I assume is measured at the bottom. Does the top of the rim move out some, or move in further.
I'd really like to run these, but I'd like to make sure my wheels still will tuck clean.
Old Nov 10, 2005 | 04:38 PM
stankubrick's Avatar
It moves the top of the rim in. I am assuming it moves in as much as the bottom moves out....
Old Nov 10, 2005 | 04:50 PM
eXciteBox's Avatar
Signature Visions
thats my car with 17 x 7 +25 wheels, OTG hub spacer shims, and OTG camber shims. as you can see the top of the wheel is sunken in back to where it was before i put all the spacers on...
Old Nov 10, 2005 | 06:03 PM
Spider13's Avatar
Cool, thanks for the pics. I wasn't sure how exactly it changed the wheel. Shouldn't have any trouble then if the top moves in. If the top moved out even 5mm I'd have rubbing issue on my fenders.
Old Nov 10, 2005 | 06:07 PM
eXciteBox's Avatar
Signature Visions
the rubbing issue oddly enough is at the FRONT of the rear wheel opening. i have to pull and roll my fender even more to stop the rubbing. take a look around the fron tof your rear wheel opening and see if the stupid metal lip is pulled down or damaged at all...
Old Nov 10, 2005 | 10:57 PM
Spider13's Avatar
No mine doesn't touch that metal lip, but only by about 2 fingernails thickness from touching that. My wheels never rub until I actually set all the way down, then the tread sits inside the wheel well. I'll have to look close at the front edge to see if I can get away with a little more clearence.
Old Nov 10, 2005 | 11:02 PM
Rocket's Avatar
I have them on my xB with 20" wheels...no rubbing!
Old Nov 15, 2005 | 08:59 AM
HoTBoX009's Avatar
Good question Spider, I wanted to know the same thing.
Great info Stankubrick and eXciteBox!
Old Nov 15, 2005 | 04:50 PM
squirrel's Avatar
Originally Posted by eXciteBox
Old Nov 15, 2005 | 05:32 PM
eXciteBox's Avatar
Signature Visions
as you can see the combined spacers push the hub out a fair amount...
and thanks brad . i have much respect for you it means a lot!
Old Nov 15, 2005 | 05:44 PM
squirrel's Avatar
Dustin,
Yeah, that has SICK written all over it.
Gotta love it! You da man!
Old Nov 15, 2005 | 05:46 PM
dougalast's Avatar
Do the camber shims come with hardware long enough to use both the spacers and the shims? I already have the rear spacers and was thinking about stacking the 2 myself.
Old Nov 15, 2005 | 05:53 PM
eXciteBox's Avatar
Signature Visions
i bought mine as a kit and it came with the longer bolts needed to stack them.
you need 8 M10 x 1.25 bolts of the highest strength you can find. safety first! . also you need 8 M10 split washers if you dont already have them.
when you stack them you have to put the camber plate against the trailing arm, THEN the OTG regular spacer shim. its easy to do tho, but it is a bit tricky lining up the dogbones, 2 spacers, and getting the bolts to line up to the hub assembly.
http://onetongarage.com/manuals/camber_combo/index.html
Old Nov 15, 2005 | 06:00 PM
dougalast's Avatar
Cool - Thanks
Old Nov 15, 2005 | 06:02 PM
eXciteBox's Avatar
Signature Visions
totally glad to help out. if you have any questions feel free to ask.
BlingSlade
Oct 19, 2016 12:39 AM
deademon
Mar 31, 2016 09:25 PM
Lexparker
Oct 23, 2015 11:39 PM
Darrenohooligan
Sep 26, 2015 07:21 AM
prescottn
Sep 22, 2015 01:30 PM
