porformance shocks?
porformance shocks?
Does anyone know if they even have performance shocks for the box? If so, where can i get them? Got tanabe coil overs but not satisfied with the drop. Resorting back to cut tein s-tech springs (4.5" drop). Sorry but don't want BAGS, nothing against it. AND NOTHING WRONG WITH GHETTO CUT SPRINGS. <---- pm me if any anyone has something to say about this comment. LOOKING FOR ADVICE not a fight. THANK YOU.
There are ALOT of shocks out there you just have to know which ones you want, how harsh the ride and what kind of use r u gonna be giving these shocks.
1.) Koni
2.) TRD
3.) Waydo
4.) Monroe
5.) Tockico
6.) Eibach
Not in any order...
1.) Koni
2.) TRD
3.) Waydo
4.) Monroe
5.) Tockico
6.) Eibach
Not in any order...
If you have 4.5" of drop with cut S-techs, you've cut a ton off the springs. For sure, a loose spring by a number of inches
You should not be looking at Konis or Monroes or probably any standard "sport shock". You need one hell of a shock to keep this from bottoming as you hardly have any travel. You need something like a very short racing shock. Adjustable compression dampening is almost a must. You need a lot of compression dampening.
If you put a XB Koni on this setup, the first big bump you hit the suspension will bottom super hard, then the springs will fall out (or off the perch).
BlingSlade
10-19-2016 12:39 AM
jthistle
10
05-09-2016 09:48 PM
Darrenohooligan
09-26-2015 07:21 AM
