Questions about TRD Springs
I purchased a set of used TRD springs from someone. I received the box only to notice that there was no identifying marks on each spring to tell me what goes where. I would imagine the tighter looking coil on the ends of the spring would be the rear springs, correct? Bear with me, as I'm new to the whole "Scion scene". I'm a DIY kind of guy, the last time I purchased and installed springs myself was on my '99 Acura TL, which were a lot bigger and looked completely different, because the suspension setup isn't the same. The springs for the Acura were different from front to back, which I figured is noticeable just by looks alone, but those springs were also different from left to right. Each spring had a different load rate, the heavier rate being on the driver's side, considering there's usually more weight on the left side of the car because of the driver sitting on that side. Is this not the case with these springs? Now that I got the springs, all I have to do is wait for the car! I also have the wheels on order (17x7 40 offset), the tires I should get soon as well, and the onetongarage shims too. Let me know please...Thanks!
Ed
Ed
Shoof,
Did you try asking the guy you bought the springs from? That's prolly the easiest way to find out.
So are you all set with the 5spd RS2.0? I remember you saying the dealer was having a hard time getting the car you wanted.
Yes, I was able to get a car, I should be seeing it within 2 weeks hopefully. I'll have more of a precise time next week.
As for asking about the springs, I did send them a message (they were from this board) and they did not answer me, which is why I asked all you guys. I think I got the answer though. Thanks!
DJ_FroZone
25
May 30, 2019 07:17 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
kleecker
Dec 31, 2014 09:42 AM
minter66
Dec 15, 2014 01:45 PM
