rubber thing not pointing out
Old Jun 17, 2005 | 11:51 PM
PSIKOTICxB's Avatar
Default rubber thing not pointing out
will anything bad happen if those things arent pointing out? ill probly reinstall it correctly tomorrow because i get something like a lil rubbing noise when i make slow turns and its annoying the hell out of me. i have trd springs on my car just in case some of you wanted to know.
Old Jun 18, 2005 | 12:38 AM
eggie's Avatar
What size wheels and tires? I had TRD springs on 215/35 18's with ZERO rubbing.
Old Jun 18, 2005 | 01:57 AM
PSIKOTICxB's Avatar
i know its not the tires..i forgot the tire size but off the top of my head they are 215/35/18, cv boots are a-okay. i probly have to redo my spring install just to make sure they are seated correctly...mainly the front left one. i know i definitely didnt have those rubber things pointing out
Old Jun 18, 2005 | 06:23 AM
SciFly's Avatar
you mean the bump stop?
Old Jun 18, 2005 | 06:56 AM
PSIKOTICxB's Avatar
the things that are labeled OUT
Old Jun 18, 2005 | 07:00 AM
PSIKOTICxB's Avatar
[/img]
Old Jun 18, 2005 | 11:27 AM
hotbox05's Avatar
you dont have those installed? i thought you meant the rubber part between that^^^^^^^^^^ and the springs. do not drive untill you put those back in.
Old Jun 18, 2005 | 12:39 PM
PSIKOTICxB's Avatar
i have those in...but that thing isnt pointing in the "OUT" direction...does that matter any? i get off work/duty in a couple hours...and i check everything out then. if pointing out doesnt matter, maybe the strut nut needs to be tightened or something.
Old Jun 18, 2005 | 02:05 PM
SciFly's Avatar
If "out" points in I think you should heed the "out" directive and make it right asap.
(but I don't know this stuff, except to know that lables like that are basic and usually -very important- to assembly safety or function.
Old Jun 18, 2005 | 10:10 PM
hotbox05's Avatar
it makes the springs sit correctly and reduce any possible problems.
Old Jun 19, 2005 | 06:27 AM
PSIKOTICxB's Avatar
i pointed everything in the right direction today and everything is nice and good...no more rubbing. it looked like the spring was rubbing against the body inside the wheelwell. while i was at it, i installed my K&N typhoon intake system since it was a lot easier to do without the strut bar on.
Old Jun 19, 2005 | 03:51 PM
PSIKOTICxB's Avatar
awww yeah...decently dropped
kleecker
9
Aug 2, 2022 05:00 AM
viciouzgamer
Feb 18, 2015 03:26 PM
luckypixi
Jan 28, 2015 05:29 PM
evolving_machine
Jan 13, 2015 08:04 PM
cb900f2
Scion tC 2G Aero & Exterior
Dec 14, 2014 10:46 PM
