Urethane bushings for front Swaybar?
Old Jul 6, 2006 | 04:40 AM
bB2NER's Avatar
Music City Scions
Default Urethane bushings for front Swaybar?
I'm looking to add urethane bushings for the stock front swaybar. Anyone know who sells them and the cost? I got the Whiteline rear bar and want the front to work to it's max. Thanks!!!
Old Jul 6, 2006 | 04:55 AM
hayalex6's Avatar
http://store.summitracing.com/partde...u&autofilter=1
Old Jul 6, 2006 | 04:59 AM
bB2NER's Avatar
Music City Scions
Those will work for the outers. I meant the ones that go around the bar where it mount up.
Old Jul 6, 2006 | 05:01 AM
hayalex6's Avatar
oh, like a sleeve type of bushing?
I think if you just find out the diameter, you can find some polyurethane bushings.
Old Jul 6, 2006 | 05:05 AM
bB2NER's Avatar
Music City Scions
I'll have to measure the bar and start hunting. I may just wait and see how it does after the Whiteline is mounted.
Old Jul 6, 2006 | 11:17 AM
jct's Avatar
jct
about the 15th post on down more info on page two... on the same link givin below...
https://www.scionlife.com/forums/vie...waybar+bushing
Old Jul 6, 2006 | 06:48 PM
bB2NER's Avatar
Music City Scions
Thanks Hornet! They come in 1 inch. I'll scope them out and see how hard they will be to swap out.
Old Jul 6, 2006 | 11:46 PM
jct's Avatar
jct
its a very tight space to work in
if your up too it your best bet it to lower the k-member if your game...
use this as a guide
http://groups.msn.com/Sorensonbrian/...isswaybar.msnw
Old Jul 7, 2006 | 01:35 AM
bB2NER's Avatar
Music City Scions
Hornet, Do the brackets that come with the Engergy inner bushings match up with the existing holes? It was hard to tell looking at the package then looking at the car. I'm wondering if they are worth the work and the money too.
Old Jul 7, 2006 | 01:45 AM
jct's Avatar
jct
yes they do line up if you have a bench grinder your gonna have to grind off a little bit off the corners on the brackets to make 'em fit good on the sub frame...
Old Jul 7, 2006 | 02:01 AM
bB2NER's Avatar
Music City Scions
Thanks much, good to know. I have a bench grinder so that's not a problem. I was more worried about the bolt holes. They looked spread apart farther.
Old Jul 22, 2006 | 08:27 PM
jct's Avatar
jct
just wonderin if you liked the install of those bushings
or if you got around too it?
Old Jul 23, 2006 | 05:53 AM
bB2NER's Avatar
Music City Scions
Yes, big improvement. I now have the rear Whiteline bar on also and all I can say Is WOW. "Bring on the cones". Even with the stock springs and steelies it handles bad a$$. Can't wait to see how it does with the lowering springs and my 17's
killahXB2
Mar 27, 2015 10:45 AM
10gxiong
Feb 21, 2015 12:53 PM
fluxingnation
Dec 26, 2014 04:28 PM
Opr8r
24
Jan 13, 2004 09:26 PM
DenZinz
22
Nov 6, 2003 08:19 AM
