Are the rear hubs rebuildable?
A quick search on Rockauto shows there is no standalone bearing offered for the rear hubs and if they don't have it I doubt you're going to find it. Besides, a new rear hub gets you not only the bearing but the ABS sensor also and replacing a rear bearing, even with access to a press, seems like far more hassle than it's worth.
Spring for the hubs...
Thanks for the replies guys.
MilehighTc I don't find this kind of work much trouble at all as long as I can get the parts and there are no surprises. I should already have the tools needed and if it saves me $50-$100 it's well worth it to me.
But If I can't get the right size bearing then I'll have no choice but to buy the complete assembly.
I'll let you guys know what happens.
I plan to work on the car Oct 6th so you won't hear anything before then unless I get new information first.
Took it apart. Not rebuildable
I pried the back cover off
And pried out the cage
It turns out the hub is stamped like a huge rivet. No bolt. The hub has to be destroyed to get it out of the bearing. The only thing salvageable is the outer housing and I have not found the new inner hub or bearing for sale.
So I picked up a whole unit from the junk yard for $15 from an xB and it went right on. I have not found ANY xA Scions in the junk yards. It must be a rare car.
Good info for future reference.
cncmech
18
04-28-2017 11:04 PM
