xb on the ground
Old May 26, 2005 | 09:51 PM
Gothbox's Avatar
Default xb on the ground
What air bag setup will let the xB sit on the ground, I know I will have to cut some stuff. All the xB's that I have seen, with bags are low but not that low, I am running 17's, will that make a diff. And what setups do you recomend other than "airrunner" b/c I don't have the cash flow for that and they are not low e nuff
Thanx
Old May 26, 2005 | 10:57 PM
Soto's Avatar
your prolly gonna have to take it to a place so the can cutt your original strut an mount the bag on that then it should sit pretty much on the ground
Old May 26, 2005 | 11:09 PM
hotbox05's Avatar
nope . you need to remove the front sway bar , cut into the subframe , extend the shock towers , remove rear shocks , and more.
Old May 27, 2005 | 07:12 AM
LilBlkBox's Avatar
If it was easy everybody would do it.....
Old May 31, 2005 | 10:10 PM
ssfastlane's Avatar
You want it on the ground ?
Body drop it... Check out the forums over on www.s10forum.com and look at some of the pics of body dropped s-10's. It's a ton of work!
Good Luck...
-SssXB
Old Jun 1, 2005 | 12:55 AM
TXboxdriver's Avatar
that truck also has a spiffy feature of having a FRAME
the Scion line of products are unibody construction
meaning EVERYTHING is a structural member
it can be done, but it will never be the same
i said "member"
Old Jun 1, 2005 | 02:07 AM
ssfastlane's Avatar
i said "member"
Oh.. Forgot to mention that one little thing ...
Thanks....
Old Jun 10, 2005 | 06:42 AM
ShortBus843's Avatar
Yeah, i dont think u can bodydrop a scion
Old Jun 10, 2005 | 07:57 AM
hotbox05's Avatar
it'd be hard as hell to just section it. let alone body drop something that has no real , "frame"
07tcscion
Oct 8, 2015 05:42 PM
DannyBoy65
Sep 21, 2015 06:23 PM
crimson10tC
Sep 10, 2015 08:44 PM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
