HELP!! Tire question.
Old Apr 27, 2007 | 04:47 AM
metro's Avatar
Default HELP!! Tire question.
I have a good deal offered to me on some rims locally they are:
Lexani Roma's
17" x 7.5
215/45/R17
Will these fit my stock xB with stock suspension? Do I need any spacers, or purchase anything special. Forgive me and I've searched some and couldn't find anything with these specifics, I found something close with 215/40/17's but not 45/17. Please let me know, time is of the essence to get a heck of a deal on these.
Old Apr 27, 2007 | 01:13 PM
metro's Avatar
anyone?????
Old Apr 27, 2007 | 01:21 PM
CHPRBOX8's Avatar
you should not have a problem may have a little rubbing on the back shock cuz the size of the tire. i have 40 on my 17's and have just enough clearance. dont get spacers they are not a good idea. get the rims and if need be just change the tires
Old Apr 27, 2007 | 01:45 PM
metro's Avatar
thats the thing though, they are brand new tires with the rims, size listed above. What should I do if they rub a little??
Old Apr 27, 2007 | 01:46 PM
metro's Avatar
and why are spacers a bad idea??
Old Apr 27, 2007 | 01:47 PM
CHPRBOX8's Avatar
from what i hear or know that one tone garage shims would be better they go behind the rear drum. ask the person selling them to see if you could put one of them on the rear to test them?
Old Apr 27, 2007 | 01:49 PM
CHPRBOX8's Avatar
some thing about they put extra stress on the studs and they could break and just arent safe from what i see on some other threads on here
Old Apr 27, 2007 | 02:55 PM
metro's Avatar
can anyone else tell me more? thansk CHPRBOX for telling me what you know, I'll be more cautious that way.
Old Apr 27, 2007 | 03:08 PM
Jan06xB's Avatar
With the new tire on the new rim laying outside down you want to measure the distance from the inside of the rim where they mount against the drum to the top of the side wall and then do the same for the stock tire to see what that distance is. Then see how much space there is between the stock tire and the suspension where it might rub. No one seems to have these measurements but if they did you could tell right away. I would say that the new rims are 3/4 inch wider in both directions - stocks are 6 inch new ones are 7.5 inch so it should not be too close BUT if the offset of the wheel is not correct then you could have a problem. The offset is the distance from the mounting surface to the center of the rim and that can be anything they want it to be but if it is not correct then the tire moves inwards or outwards from the stock position. It is supposed to be 40mm offset (1.57 inches) but you really need to measure the sidewall bulge of the tire when mounted to figure out the clearance.
Old Apr 27, 2007 | 03:18 PM
metro's Avatar
I don't know the exact offset other than the measurements I gave above, unfortunately I don't know much about tires/rims. I can tell you they are 17" Lexani Roma's, the original Roma's not the Roma II
Old Apr 27, 2007 | 04:07 PM
Jan06xB's Avatar
Read this Thread
https://www.scionlife.com/forums/vie...highlight=rims
Towards the bottom dudehitt post pretty much clears it up - the offset it 38mm stock and a Millimeter either way is not worth talking about - 25.4mm to an inch. Sounds like you should try to keep the tire centered on the bearings to avoid any alignment and steering problems but the inside clearances will determine that - you don't want anything rubbing. Any chance you can just get them put on and see how they fit? The offset is critical to not rub and it is raining here today and I am not crawling out and getting under my xB to check for ya ok.
WOW they sure are some BLING BLING Wheels!
Old Apr 27, 2007 | 06:19 PM
metro's Avatar
yeah its raining here to or I'd try and see if I can put them on. I called Lexani and they said the offset is 43mm. Does this change anything?
Old Apr 28, 2007 | 02:04 PM
metro's Avatar
Well all, I put one on the back yesterday and it still had almost an inch before it would rub the back shock, etc. Looks like I'll be okay. Thanks for the help and if anyone still has any advice/recommendations, please feel free to post.
Socialdisorder
Apr 3, 2015 01:35 AM
ploniaczysko
Scion tC 1G Wheel & Tire
Jan 28, 2015 02:15 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
rodney_ray
9
Dec 31, 2003 04:40 AM
rodney_ray
Dec 23, 2003 08:41 PM
