I want big sidewalls. Would these tire sizes fit?
Old Sep 22, 2003 | 11:32 PM
wonderworm's Avatar
Default I want big sidewalls. Would these tire sizes fit?
205/50 R17 or 215/45 R17. I know these are non-standard and increase the circumference, but i just want to have bigger tires overall along with a larger rim. Do you think these tires would rub?
Old Sep 23, 2003 | 02:02 AM
its_ikon's Avatar
do you have springs installed?
Old Sep 23, 2003 | 07:45 PM
wonderworm's Avatar
Default Oversized tires
No plans to lower it or anything like that. I'm also considering 205/55 R16. Do you think oversized tires would lower my torque since the wheel is larger? On poster said 205/55 R16 pretty much fits.
Old Sep 24, 2003 | 12:16 AM
Kendo's Avatar
Default Tire Sizes
The 205/50R17 will increase your overall wheel diameter by 5.61%. When your odometer reads 1000 miles, actual milage will be 944 miles.
The 215/45R17 is closer. This will increase overall diameter by 3.7%. Odometer reading of 1000 miles will equal 963 actual miles.
The closest size up other than the 215/40R17 which is pretty much a dead ringer for OE height would be 205/45R17.
Keep in mind that if you go with the 205/50R17 your overall wheel height will be even taller than the people with the 19" wheels with the 215/35R19's... Make sure the offsets of your wheels are okay or you're bound to have rubbing issues.
Old Sep 24, 2003 | 12:23 AM
nacy333's Avatar
Default Re: Oversized tires
205/55/16 fits...and yes, they do make the car feel a bit more sluggish. While my wheels are pretty damn light, the tires themselves weigh more, I'm noticing a bit of a difference when braking too. While the size is still less than that of putting on 19s with 215/35/19, I get minor rubbing on plastic bits that should have been pulled inward towards the wheel well anyway (I seriously think its a defect cos its only on the driver side not the passenger side)....but remember, my car is lowered too.
Old Oct 15, 2003 | 08:02 PM
wonderworm's Avatar
Nacy, what offsets are you using for your tires?
Anyone know the lowest offset I could go using the following without rubbing (no plans to lower):
1. 205/55/16 or 205/50/16
2. 205/50/17
3. 205/45/17
4. 215/45/17
Old Oct 15, 2003 | 09:01 PM
Kendo's Avatar
Default Offset
Offset will vary depending on the width of the wheel. A 17×7 ET35 and a 17×8 ET35 will sit differently regardless of what tire you put on there. What size wheel are you using?
Old Oct 15, 2003 | 09:05 PM
ScionVan's Avatar
2. 205/50/17
3. 205/45/17
4. 215/45/17
The offset you can run isn't directly related to the tire size you want to run. You usually actually want to figure out your wheel fitment first, and then choose a tire to make it work. The steps to choosing footwork for your car:
1) determine what your budget is!!
2) decide on a wheel diameter to run
3) figure out what wheel design you like (5 spoke, multi-spoke, fin, mesh, dish, etc.)
4) and here's the big one: how crazy do you want to go??? If you opt for crazy, you will go with an offset in the low 30s-mid 20s (depending on wheel width). If you decide on going super crazy, you will go with wheels with offsets in the low 20s, and widths of 8"+, and you will have to do a little rolling of the wheelwell lips (no biggie). And if you go super super crazy, you go with wheels of at least 8.5"+ width (up to 9.5" in the back), offsets in the low 20s-high teens, roll your wheelwell lips, AND run some camber!
5) choose a tire size. >HAHA<
Old Oct 16, 2003 | 05:20 AM
wonderworm's Avatar
i'm supa CCrazy!!
Actually, I'm thinking no larger than a 17x7 wheel. Just because I may use 205 tires and I want my tire to stick out some and hit the curb before the rim does. So my finalists I think are:
1. 17x7 205/50/17 +25 offset
2. 17x7 205/55/16 +25 offset
That is if i can find these larger tires. It hard to buy tires matched 5% higher than standard diameters.
Old Oct 16, 2003 | 07:14 AM
nacy333's Avatar
wonderworm >> you can run those offsets just fine...at least I think you should be able to. My wheels are 33 offset and for getting matching wheels (same offset and width both front and back) I think they're pretty damn flush.
A 205 should do you fine on most 7 inch wheel widths. My tires are 'slightly' thicker than the rim but only barely but yet I can lay them flat down face side on the ground and the rim will not touch. Be careful however as it may vary depending on the tire manufacturer. I have Falken Azenis and they seem just fine. Another thing to note is that I have the TRD springs with a 1 inch drop and they rub at full wheel lock. If you do not plan on lowering your car however, you should be fine.
scionlife
371
Jun 2, 2015 11:00 PM
George
Regional - Pacific South
200
Feb 11, 2006 01:48 PM
scioninla
Oct 30, 2003 08:01 PM
Besk_one
Oct 18, 2003 08:41 PM
BUzzBUcket
10
Oct 12, 2003 07:19 PM
