Sportmax 006 on Infiz xB
http://custom.autos.yahoo.com/galler...&start=5&sel=8
I saw your site with 17x9 sportmax 006 on rear. Are you running spacers or shims?
Hey - that's my xB that crash linked to in the 1st post.
I'm running:
17x8 up front w/ 215/40-17 Falken FK452
17x9 rear w/ 225/35-17 Falken FK451
No spacer required up front, 10mm hub shim & shaved a notch in the weld spot of OEM swaybar. Fitment is close but absolutely no rubbing in front or rear, even loaded down w/ 5 ppl. Car's dropped 1.8" with Eibach Pro Kit.
I'm running:
FYI since I have so much tire clearance with the setup, i would recommend going with a slightly larger sidewall in the rear next time. I saw some of the guys running these wheels in 18" setup, and the crazy rubbing issues they are having, so I got 35 series in the rear but next time i'd look for some slightly taller ones.
Originally Posted by Short_Bus
don't do that...just lower it more and close that tire clearance!
You could easily run 17x8 all the way around with absolutely no rubbing.
If you're already putting on a 10 or 15mm spacer in the rear, why not stagger and do 9" in the rear? I've got mine dropped 2" and absolutely no rubbing after several months of use.
iheartzombies
48
Apr 9, 2008 01:29 AM
julez007
Scion tC 1G Wheel & Tire
10
May 3, 2007 02:32 AM
arizonaturbo
Oct 10, 2006 08:53 PM
