Tire Pressure question
there is a wide range of possible, safe pressures.
Load and comfort requrements are often at odds in deciding your best standard air pressure.
In general: if the tire is wider than stock then it need not have more air pressure than stock.
Consider the contrasting example of the temporary spare tire. It is narrow and so, to maintain it shape under load it is spec'd for 60PSI.
All tires can be inflated safely up to the pressure listed on the sidewall. Rarely, though, is this a good idea.
We want the tire face to wear evenly. Inflation in fitting proportion to the load will allow the tread face to wear evenly. And will assure minimal heating of the flexing sidewalls if you run at highway speeds. (heat destroys tires. underinflated tires run hotter)
A tip I read at a responsible site advocates this means of setting tire pressure: air enough to create an even temperature rise across the face of the tread.
A non-contact IR thermometer could be handy for precision setting of your tire pressures. Scan across the face after a drive. Adjust pressure upwards if the sides are hotter than the middle, and etc.
hope this helps,
reid
hope this helps,
reid
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
