Glare shields. HID help. Guru's chime in!
Im just about to try again with HID's in my reflector housing lights. I did once before on my last car and it lasted me just 1 night. So I wanted to know if there is a company or anyone who would know if I can get glare shields for the H4 style HID bulb to aid in the cut off. Website link/referral on here? Maybe there's a kit that has one built in like the Toyota Prius since that uses HIDs in reflector housing as well?
maybe even clifford can chime in and help. He's local in AZ, and will be getting my HID's through him again like before. So someone/anyone's help is much appreciated.
If you have a bulb with the halogen highbeam built in, you will have glare, no matter what.
I recall the set of H4 bulbs that Umnitza sends out has a very nice shield on em...
I just bought sonars and 9006 bulbs to eliminate glare entirely.
Originally Posted by enjoi
I bought my HID from mobile HID h4 4300k and i got the anti glare shield. Very good product. It is in the stock reflector housing. I've been using it for roughly 3 months, so far so good.
Originally Posted by burstaneurysm
They're usually attached to the bulb... otherwise, google 'casper shield'.
Mobile HID.. mine have been on over a year. no troubles. stay away from McCulloch the ballast don't last and arent water proof and shock proof.
or you can do a Retrofit which is much better then ay plug and play kit. but it usually cost more and more time consuming. but the results are MUCH better.
search through the classifieds for Mobile HID. tell em firesquare sent ya ;-)
Originally Posted by stenger
screw mobile HID, buy from a name that has been around for a long time..
Happy holidays to you buddy!
You can fab up a set of these
http://www.casperselectronics.com/mm5/merchant.mvc?
Take them then merge then with the base of an OEM halogen bulb.
We did them back in the day like 1999 lol
Smashed the headlight in a bag
then soldered it to the shields ;)
after FULLY reading your first post
you have h4
no cutting required, just order and VOILA'
not PERFECT cutoff but better then without!
Happy holidays
http://www.casperselectronics.com/mm...Category_Code=
you have h4
Happy holidays
Guilles_Tc
Scion tC 2G Aero & Exterior
10-15-2015 03:09 AM
