Having trouble with my tailights...
Old Aug 2, 2006 | 05:47 PM
Archngl's Avatar
Default Having trouble with my tailights...
When my running lights are on, the right rear Red Bulb is on, but the left is not.
So... I burned out the left bulb right?
no. for 2 reasons.
1. It's an led bulb I purchased 2 weeks ago, and
2. When I hit the Brake, the left light is on, but the right is not.
Help?
Old Aug 2, 2006 | 06:04 PM
pooder's Avatar
Default Re: Having trouble with my tailights...
Check your ground connections; these sound like grounding problem symptoms to me . . . .
Old Aug 2, 2006 | 06:08 PM
Archngl's Avatar
<--- doesn't know how to do that.
Old Aug 2, 2006 | 06:38 PM
TuningIsLife's Avatar
Na, sounds like the connection for the parking lights on the left tail light it having problems. Get a Multimeter, tap that wire, and make sure it reads 12v when the parking lights are on. If it doesn't find out why. If it does, try futher down the line closer to the tail light, till you are testing the bulb connection itself. Then have someone help you hit the brakes and test that connection also.
Old Aug 2, 2006 | 06:49 PM
Archngl's Avatar
I'm not sure voltage should be an issue... I mean... the left works with the brake, and the right works with the headlights...
Altho... I know nothing about cars... lol
So you could be absolutely right!
Any more suggestions?
Old Aug 2, 2006 | 06:58 PM
AH I didnt even notice that they flipped.
hmmm.
could be because the bulbs were dual filiment and the LEDs aren't. But I have to check into that.
Old Aug 2, 2006 | 07:04 PM
evosky's Avatar
i kind of had this problem when i was putting my lights back in after doing a partial redout. it turns out that i just needed to tighten the bulb connection, so just check those bulb connections in the back of the tailight housing. if that's not your problem, then something burned out or short circuited.
07tcscion
Oct 8, 2015 05:42 PM
DannyBoy65
Sep 21, 2015 06:23 PM
Chrono
Aug 25, 2015 05:59 PM
iFangy
Aug 13, 2015 05:10 AM
