Headlight Sockets Melting
You'd need to order an HID kit that would fit in your current headlights. If you're running a 9005 bulb now, order a 9005 kit.
The connector that currently connects to the 9005 bulb would connect to the HID ballast.
I'm now just going to order this 35w hid kit from ddm tuning...i know its taken me forever...just wondering how will this work with High/Low beam? Will i just not have a high beam?(I never use it anyways)
Well, with the setup you have, you'd still have high beams...
Rather than plugging the 9005 connector into the bulb, you'll connect it to the ballast.
I recommend getting the digital kit. The low ignition voltage will allow you to run them without a relay harness.
When you flip the high beams, the low beam HID will cut out and you'll have the halogen low beam on.
Make sense?
Make sense?
Well I ordered it last nite! I am going to order new 9005 sockets today aswell for the low beams; that way I know they are good and not melted! I will post some pics once its all setup or be back if I screw something up! Thank you for your help!
So I finally got my HID kit today! I'm so excited! I managed to get it to work; but the brackets they sent I don't under stand how the hold the ballast...the ballast has nothing that I can put a screw into & the brackets are flat with one hole at one end and 4 holes at the other end it came with 6 nuts and screws....I really want to make sure its secure..any ideas?
vi3tb0i09
Sep 23, 2015 08:32 PM
atlantaemail
Sep 20, 2015 02:03 AM
