HID Kit problem with the high beams
Originally Posted by low_down_xb
just follow the diagram, power is split between the two bulbs, hook them both together and one ground get connected to the black/white wire and the other is connected to the black/yellow wire, it grounds itself thru the switch, just connect a test light on the +battery side and touch it to the black wires to find out which one works the low beams and then touch the other black wire to see if it does the high beams, its really not that difficult
Thank you
ok here are some pics
both + wires from low beam and high beam hook them together
connect your test light to the negative side of the battery and probe the black wire w/red stripe, you light should come on, this is the power wire
next is the grounds, place the clamp on your test light to the + side of the battery and probe the black w/white strip, and turn the headlights on low beam your testlight should be on, connect you ground from you low beam bulb to this wire
now its time to check the high beams using the same method as the low beam, probe the black w/yellow strip wire and put your high beams on, the test light should be on, just connect the high beam ground to this wire and everything should work just fine
now, [/img]http://a511.ac-images.myspacecdn.com/images01/57/l_b6349fc0698f03f1cc584bb5b699d3be.jpg[img]
this headlight system has constant 12v power and is ground through the heallight switch, hope this helps and you can always go back to the diagram on the first page.
[/img]
i can try but to get some pics, but you can just use a test light to find it, ill post them later to help you guys out
Thank you thank you thank you Low Down xb!! I just followed your steps and now the low and high beams both work perfectly as they should!! Your post should be in the tech section! Thanks again.
jaspercanda
Dec 28, 2014 10:09 AM
Basebllstar
Dec 17, 2014 07:30 PM
minter66
Dec 15, 2014 01:45 PM
umnitza
Dec 1, 2014 06:26 PM
