Hid Probs
Old Jan 10, 2009 | 02:35 AM
The-SkyBox's Avatar
Default Hid Probs
i got a slight problem with my right HiD...
sometime when i turn on my lights it turns on then quickly turns off like it blew out but it didnt... any1 know whats going down and how to fix it?... its an 8k H4 bulb on a 04 xb...
battery issue? or is it that i have to wait for my car to switch the alternator?...
Old Jan 10, 2009 | 02:48 AM
burstaneurysm's Avatar
Are you running a relay harness?
The-SkyBox's Avatar
yea i am
Old Jan 10, 2009 | 02:51 AM
Check all of the fuses on the relay harness. Check the ground, check all of the connections.
Old Jan 10, 2009 | 02:53 AM
firesquare's Avatar
also make sure if you have a harness, that its directly connected to the battery. or swap ballast, if it travels to the other side, you have a bad ballast.
Old Jan 10, 2009 | 02:57 AM
The-SkyBox's Avatar
thanks for the heads up
Old Jan 10, 2009 | 03:10 AM
evosky's Avatar
good info to know. i'll have to recheck my wiring again also to make sure it's right. i have a suspicion that it's not 100% correct ...
Old Jan 11, 2009 | 02:09 AM
crex149's Avatar
That's uncanny. My HID kit did the exact same thing on the exact same side. I finally wired the passenger side up on a secondary switch so that I could pulse the power on and off independently of the other side, so it wouldn't look like I was flashing my headlights. Each had there own seperate relay, to the battery, using 10 gauge wire. It didn't matter which ballast was on it either. It stayed with the bulb. Meant to buy a replacement bulb, but finally got fed up and took out the projectors and went back to factory.
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
hondajt
Dec 14, 2015 12:54 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
Renuco612
Sep 16, 2015 09:01 AM
