How to bake projector headlights on my XB!!!!!!
Old Apr 20, 2007 | 07:44 PM
StarSk8er_00's Avatar
Default How to bake projector headlights on my XB!!!!!!
Just like the subject says I really need to find out how to do this! My right front projector headlight has water in it and I need to reseal it all. I have searched all over the web on how to do this and their is nothing (that I have found) that shows how to do this for the XB. If someone gives me instructions then I am willing to make a DIY with pictures. I just really need to get this done ASAP! I know that it is probably easy but I dont know what temp, how long, what to use to keep if from melting on the tray, etc. I really appreciate it!
Old Apr 20, 2007 | 08:35 PM
jgonzalvo's Avatar
see this in tech....
https://www.scionlife.com/forums/viewtopic.php?t=159913
this is for stck headlights but it should work with the projectors as well....
Good luck....
Old Apr 20, 2007 | 08:37 PM
L4rry_B1rd's Avatar
why would it be any diff than baking any other headlight... there are walkthru's all over the place...
Old Apr 20, 2007 | 08:39 PM
Thanks a lot..... I wonder how I missed it? The only question I have if you can answer it is wouldn't the plastic melt on the grills in the oven?
Old Apr 20, 2007 | 08:40 PM
I guess it wouldn't but why not post a question on here and see if anyone has specific to the scion answer? And plus I had questions to ask and since I am already a member here I found it easier to ask them on here.
Old Apr 20, 2007 | 09:01 PM
jgonzalvo's Avatar
put 'em on like a cookie sheet...one at a time....
Old Apr 20, 2007 | 09:03 PM
Sorry to sound redundant but wont the hot surface melt the lights? The reason I keep asking is that I saw one write up for the wrx and they said put a towel on the baking sheet and then the lights on that.....but to me that sounds like a fire waiting to happen....especially since he baked for 30 minutes on the towel...
Old Apr 20, 2007 | 09:33 PM
1epoXyBox's Avatar
Here is the oven method on stock lights. Shouldn't be too much different. I just put the light right on the rack, and no melting occurred. My fingers are the only thing that melted... I suppose the plastic might melt if it was a cheap plastic. The best thing to do is keep an eye on it while its in the oven.
https://www.scionlife.com/forums/vie...573&highlight=
Old Apr 21, 2007 | 01:30 AM
low_down_xb's Avatar
has anyone tried using a heat gun? i dont know how i feel about putting plastic in my oven then cooking in it, i dont want my food to taste like plastic
Old Apr 21, 2007 | 06:48 PM
NewMexicoxBPhatBoy's Avatar
Oven Method is very easy, i think you put the time too 225 for about 12 minutes on each headlight, than just pry up the latches one by one, and pull it will come off very easily, i did this with my stock headlights to clear, and it worked perfect.. but be sure to press it back on reallly hard, because otherwise it will fog up and leak alot, like is happening now to my stock driver side, its starting to fog up what does anyone recommend on sealing it with?
Old Apr 23, 2007 | 08:06 PM
xbizzle562's Avatar
Hmm StarSk8er l have alomst the same problem execpt mine fog up But i'm confused with bakeing them and reseal them with the same glue it came with. That's the OEM glue. from the OG head lights, The lights that we have are aftermarket. If they are foging up or getting water inside it's because the glue or silicon is not as good as the original. It seems like baking them might not work using the inferior material that it comes with. Rallying the scion told me to use RTV silicone glue. to reseal them after opening them up I think this might work he said RTV can be bought at any hardware store, or auto store, he bought it at NAPA, it has a gray/silver look to it. comes in many color, depending on its useage.
what do you think?
Old Apr 23, 2007 | 08:25 PM
I was thinking about the same thing. I think if he says that silicone will work then I will probably try it since it can't be any worse than whats on there stock. I really want to take out the yellow plastic piece inside the lights when I do this but then again that would mean I would have to bake the other headlight that is sealed fine...... hmmmm....
Old Apr 23, 2007 | 09:19 PM
xbizzle562's Avatar
what lights do you have ? These are mine http://ssuperstore.com/product_info....roducts_id/304
Old Apr 23, 2007 | 09:32 PM
if you dont like the projector you can always use the screwdriver method like i did when i had the factory lights
Old Apr 24, 2007 | 12:42 AM
xbizzle562's Avatar
screwdriver method ? please do tell
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
alias55
Scion tC 1G ICE & Interior
Sep 22, 2015 07:50 PM
DannyBoy65
Sep 21, 2015 06:23 PM
atlantaemail
Sep 20, 2015 02:03 AM
