!!!Signal Light Question!!! only seen this once...have you?
well the other day i was driving my box...and bumped to another box that was on
the oppossing traffic...he was making a left and i noticed that he made his
OEM fog lights signal at the same time his headlight signal would blink which
i thought looked pretty cool...has anyone seen this before? i asked my brother and
he said that you can buy that at your local autozone or pep boys.but i could'nt find any
would you peeps know where i can actually get this?
I'd imagine just rewiring the ground wire on the fog wiring to use the ground of the blinker would do it.
Then you just leave the switch on, and it should run with the turn signal. Shouldn't be too hard.
would there be any other way to make the fog light blink compared to using the fog
lamp itself.and to avoid the bulb to burn out.???
thanks guys!!!
It shouldn't burn out any faster.... In fact, only using it as a turn signal (and not as a fog light) would probably make it last longer.
Although the factory fogs do look like old school bumper lens turn signals, I think the standard turns are plenty bright. Not to mention the blinking side markers. No need to blink the fog light too.
-THE DON
-THE DON
that's a easy mod... i did that to mine but what i did was added a wire from my turn signals to the foglights and installed a diode in line to keep from back feeding in to the foglights if i have the foglights on at night...or u can go this route..my buddie drilled a hole in fog light assembly and bought a light bulb from pep boys or autozone and tapp in to the turn signal wires...
my bro. told me to do the same thing but
i didnt where to start the whole. how did that light bulb look like because when i went
i couldnt find any???
thanks guys!
i mean? i dont want to get pulled over just having a SUPER flashing signal light!!!
i used a 194 bulb spocket and used a 194 clear bulb..at one time i used a 194a bulb (amber) bulb...i drilled a hole onthe bottom of the fog light housing to fit the bulb socket and the ran wires from the turn signal to the bulb socket...
where exactly did you drill the whole for the bulb?
would there be any pics that you can post up so i can have a clue how at least these
things look. iam a noob at this stuff so please bare with my questions. ive never seen
a 194 bulb sprocket before what is that by the way?
im thinking about doing this
but making the fog light a dedicated turn signal
i was thinking splicing teh line from the turn signal adn rewiring it so it goes to the fog
but for teh ground woudl i have to run it back to teh corner bulb ground or can i use teh stock fog ground
(or any ground for that matter)
xBSciontist
06-18-2019 03:06 PM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
Opr8r
20
02-25-2004 11:29 PM
