A tip for installation of the JDM xB foglights.
Old Aug 15, 2006 | 08:02 AM
peteski's Avatar
Default A tip for installation of the JDM xB foglights.
If you bought the JDM factory bB foglights for your xB, they are drop-in fit except for the switch. While the JDM switch has a cool light in it, it will not directly plug into the factory xB wire harness connector.
So, one option would be to cut the connector and hardwire the switch in. Or buy a generic male-female connector and wire it into the switch circuit. Still a pain to attach (solder) the wires into the switch.
Here is a much better method. Switch has a male part of a standard Toyota 6-pin connector. Identical connector is used in the xB taillight circuit (and probably few other places). So, go to any local junkyard and find some junk Toyota vehicle. Doesn't have to be new. Seems that Toyota has been using the same connectors for at least the last 10 years.
I did just that, and found connectors which are perfect match for the JDM foglight switch. Just cut them out of the wire harness and leave couple of inches of wires. That will allow you to splice the connector into the existing xB foglights wire harness. And it is plug-n-play to the JDM switch, so it can be easily disconnected.
Here are some photos of the switch and the connectors I've found in the bone yard. They come in different colors but they all fit perfectly.
Old Aug 15, 2006 | 03:28 PM
dekthai's Avatar
good tip!
Old Aug 15, 2006 | 03:56 PM
bbscionxb's Avatar
thats a cool tip what type of model toyota did you take your off. just order my set of jdm foglights.
Old Aug 17, 2006 | 03:48 AM
peteski's Avatar
All Toyotas from the last 10 years or so should use the same connectors as Scion.
One I pilfered the connectors from was a Camry Wagon and aonther one I don't know as the interior was ripped apart and the hood and trunk lids were gone. But that made it even easier to get the connectors.
Old Aug 17, 2006 | 04:42 PM
stick_1NZ's Avatar
Thanks for sharing the wisdom.
Old Aug 21, 2006 | 02:01 AM
Gsnorgathon's Avatar
^What he said.
Old Dec 9, 2006 | 03:22 AM
Fran82's Avatar
Nice tip. That actually looks like the rear speaker connector from the back of the radio too. If you upgrade your stereo you could remove the speaker plug or I think Metra makes one.
Old Dec 10, 2006 | 03:17 AM
peteski's Avatar
Yup, that is a standard Toyota connector. It is used several places in the car. And as you say, someone else in another post showed that a harness with this type of connector is available on eBay (could be Metra). In my situation junkyard was quicker and cheaper than buying it online.
Old Oct 16, 2007 | 11:16 PM
ShelbyGLHS0331's Avatar
Does anyone know the part # for this illuminated JDM foglight switch? All I need is the switch.
Old Oct 23, 2007 | 12:48 AM
peteski's Avatar
Here are part numbers (from the Japanese installation instruction sheet):
Switch: 84160-60050
Relay: 90987-02027
RH light assy.: 81210-52020
LH light assy.: 81220-52020
Old Oct 23, 2007 | 11:55 PM
Default JDM bB fog light kit part #'s
Thank you Peteski! I'm going to try to order the switch from the dealer tomorrow.
Switch: 84160-60050
Relay: 90987-02027
Old Oct 24, 2007 | 07:55 AM
peteski's Avatar
No problem. The switch will probably cost you $50 at the dealership!
Old Oct 24, 2007 | 08:50 AM
sparcshinobi's Avatar
That's a kick-butt mod! Nice find!!!
Old Oct 25, 2007 | 09:19 AM
peteski's Avatar
Thanks sparcshinobi!
Old Jun 12, 2008 | 07:29 PM
OakToddler's Avatar
I found this with all that work done using a connector.
It seems a little cleaner.
http://cgi.ebay.com/ebaymotors/_Car-...m250258642842&
Old Jun 12, 2008 | 08:45 PM
aalbertson3's Avatar
^ Bumping all the JDM Fog threads?
Andreas24
38
Sep 22, 2015 06:23 PM
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
