door lock problem
door lock problem
hi
I am writing about door lock issue in south korea.
plz understand if the grammar is wrong
I have a scion xb 2005.
door is not locking by remote and key. but driver door switch works fine. so its crazy.
I replaced a driver door actuator but not solved
I want to know how to fix
the situation is the below
1. If I use the key for locking, driver door locked only
2. If I use the remote for locking, all door is noting (not work)
3. If I use the driver door switch for locking or unlocking, works fine
4. If I use the key and remote for unlock, works fine
thank you for reading it and I'd like to know how to solve it
from beyond the pacific ocean...
The only time I've had an issue with the doors locking from the fob is when something wasn't completely closed. Open and close all the doors, trunk, and hood and then see if the fob works any differently.
Also I've seen some cars that have a switch that changes how the fob operates. This may be in the glove box or somewhere else. Maybe someone with an xB will chime in as I'm not as familiar with them.
did you have the same all problem?
according to your advice, I'm going to get oem actuator
thank you for reply
god bless you
thank you for reply.
I'll keep that in mind
scionguy2006
10-15-2021 05:08 PM
schmanderpanders
09-23-2013 01:02 AM
Rizzie
01-28-2010 12:45 AM
zim6699
09-15-2008 01:55 PM
