REAR DISK BRAKE QUESTION
The cars are built on the same platform, and use many of the same parts. i would imagine that the electronics are the same for both cars. Any work in a service department have some parts number or fixed both cars and knows if they look the same??
you'll be taking your life into your own hands at that point... you would need to permanently disable the VSC and the EBD because the system will apply x% brake pressure as required to elimate skidding out of control, or correcting a skid... so you want to up the size of the rear braking capacity, but you aren't spending a dime on the front...
imagine having the strongest brake in the world on your BMX front tire... panic, squeeze with normal exertion... and kaboom... you are on your butt...
now add 2400lbs of steel...
Slopoke21m
54
Apr 23, 2007 12:25 AM
