LED Replacement ?
Old Oct 27, 2019 | 01:42 AM
D_xB_4me's Avatar
Default LED Replacement ?
Hey all I need some advice on my 08 xB headlights. Has anyone done the LED replacement in stock headlights and if so any
suggestions on what ones to use and what ones to stay away from. I like the LED brightness and clarity but I don't want to fry
on coming traffic eyeballs. I've been all over the interwebs looking but I see several applications and many say very or extra bright.
Also hopefully I can get ones that don't pulsate.
Any input would be greatly appreciated.
Thanks
Old Oct 28, 2019 | 01:09 AM
D_xB_4me's Avatar
Anyone?
Old Nov 6, 2019 | 06:04 AM
ricnoval's Avatar
I have not, will not.
Old Nov 6, 2019 | 08:53 PM
D_xB_4me's Avatar
Thanks for the input ricnoval.
Old Dec 19, 2019 | 06:47 PM
thalittleengine's Avatar
I just tried with these....
Amazon Amazon
they flicker and the hi beams only worked on the right side. they are being returned. was looking here to find out what others are having success with.
Old Dec 20, 2019 | 05:25 PM
Greg S's Avatar
When looking at LED replacement bulbs you want ones that mimic the looks of the stock filament in a halogen bulb to get proper light output. So a bulb that is as flat as possible and has the LEDs as close to the center line as they can be. I just put this set in my daughter 07 Civic and they work great,
https://www.amazon.com/gp/product/B07FXZMBGP/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07FXZMBGP/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
That being said, generally HID bulbs work better in a projector headlight like ours than LEDs do. I used the LEDs for her car because the Civic uses a reflective housing similar to our high beams.
Old Dec 21, 2019 | 02:41 PM
What's your opinion on these?
Amazon Amazon
Not sure how the civic bulbs install but on the scion there is a rubber piece that goes over the bulb after the bulb is clipped into place. then after the rubber piece is pushed on creating an air and water tight seal; the wire harness is pushing onto the light.
the issue i had was that the "canbus" which is hardwired in line was too big. I was concerned about moisture getting into the headlamp assembly so I forced it into the hole and black taped it. (EDIT: when i went to take the pictures the rubber pieces that
I pushed on as well as I could were hanging out of place. so this isn't going to work unless someone has a fix.)
otherwise they are as bright as any high end lights you see on the road.
__________________
Old Dec 22, 2019 | 06:12 PM
RichBinAZ's Avatar
Is that a fan on the end of the bulb? The fan will need to circulate air, so you will need to save the rubber grommet in the trunk with the spare tire
Some of the suppliers show that you need to cut out the rubber boot to go over a static heat sink.
Under the amazon item they show a grommet for the bulb perhaps?? (frequently bought together)
Old Dec 23, 2019 | 12:23 PM
isn't that rubber boot supposed to prevent moisture from entering and collect on the headlight lens?
Old Dec 27, 2019 | 02:19 AM
RichBinAZ's Avatar
Yes, but I don't thing you can use the original with the LED bulb. This was suggested under your amazon link - it might work
https://www.amazon.com/CAR-ROVER-Headlight-Dustproof-Conversion/dp/B076Q9D52Z/ref=pd_bxgy_263_img_2/142-9325896-0341333?_encoding=UTF8&pd_rd_i=B076Q9D52Z&pd_rd_r=52b72466-a46e-4345-8a7d-ff3785000202&pd_rd_w=75qIn&pd_rd_wg=mBEvP&pf_rd_p=09627863-9889-4290-b90a-5e9f86682449&pf_rd_r=61SFXR97Y7KRC70KT7DN&psc=1&refRID=61SFXR97Y7KRC70KT7DN https://www.amazon.com/CAR-ROVER-Headlight-Dustproof-Conversion/dp/B076Q9D52Z/ref=pd_bxgy_263_img_2/142-9325896-0341333?_encoding=UTF8&pd_rd_i=B076Q9D52Z&pd_rd_r=52b72466-a46e-4345-8a7d-ff3785000202&pd_rd_w=75qIn&pd_rd_wg=mBEvP&pf_rd_p=09627863-9889-4290-b90a-5e9f86682449&pf_rd_r=61SFXR97Y7KRC70KT7DN&psc=1&refRID=61SFXR97Y7KRC70KT7DN
Old Aug 17, 2021 | 12:01 AM
makros's Avatar
Shop around and get fanless LEDs.
Old Aug 17, 2021 | 04:51 AM
DannoXYZ's Avatar
Moderator
Moderator
Yes, higher quality bulbs use copper heat-pipes and heatsinks instead of aluminium. Conducts heat much, much faster, so doesn't require fans. Also more durable and longer lasting. Fans don't last very long, especially if you live in humid and rainy climate. When fans die, so does your bulbs.
interesting
Scion tC 2G Aero & Exterior
Feb 13, 2013 03:03 AM
MightyP
31
Jul 6, 2011 07:24 AM
furiousPunch
Scion xD Aero & Exterior
Apr 7, 2010 08:35 PM
LEDmod
Scion tC 1G ICE & Interior
16
Aug 22, 2007 12:59 PM
vvti24
Scion tC 1G Aero & Exterior
Mar 28, 2006 03:14 PM
