Rear Wiper Delete...
Old May 31, 2011 | 03:38 AM
ScionFred's Avatar
Thanks DMA 808.
To Occam's question, most do it for aesthetic reasons but in my case I'm considering doing it to reduce uneccessary weight. A rear wiper is nice to have but much like other niceties like headlight washers, it's not exactly necessary. The spare tire, jack, etc. is going to be replaced by a bottle of slime and a small air pump.
Old May 31, 2011 | 07:52 AM
isomswim's Avatar
So I'm all for doing this "mod" but my first question is what about the dang "squirter." Its still going to be above the window with no reason to be there. Any body removed both?
Old Jul 5, 2011 | 05:15 PM
eight08customs's Avatar
nice
Old Jul 5, 2011 | 06:08 PM
DMA_808's Avatar
I was thinking of flipping it upside down or modify it so that when you get tail gaters you can just spray em with some washer fluid
Old Aug 21, 2011 | 01:58 AM
S_B's Avatar
S_B
We remove the wipers and put back up cameras in them and the for squirter pull the spout off of the little rubber nipple it points straight out and will reach a good 6+ feet right out the back. Also if you don't use your wiper on the back it will eventually rub a mark in the glass that's hard to get off.
Old Sep 17, 2011 | 04:04 PM
kingofthecrate's Avatar
Where are you guys getting your back up cameras from?
Also removing the nipple and shooting that hose straight back is a brilliant yet likely way to get yourself in the streets of Los Angeles..
Old Sep 17, 2011 | 04:06 PM
Also like to add that rain-x(ing) your windows is a great way to reduce water build up on the windows.. I do it to the production trucks my company owns and it helps out the drivers a lot.
Old Feb 21, 2012 | 08:21 PM
sjthompson01's Avatar
Which backup cameras are yall using? DIY would be nice. The rear wiper does seem to work if its nasty out and you window is dirty but I guess it will go cause it looks better without. I think I am going to do a multi step paint to try and match factory color really close.
Old Feb 21, 2012 | 09:41 PM
alfundo's Avatar
Lehigh Valley Scions
i used one of the ones on amazon with night vision, they are a tad bigger then the stock hole so you will need to file a bit if you use one of those. i think there are 2 brands...pyle and xo vision that come to mind
Old Feb 22, 2012 | 12:44 AM
Thanks man I am going to look into it
Old Oct 17, 2017 | 09:24 PM
MR_LUV's Avatar
Administrator
Administrator
Default DIY Tech: Rear Wiper, Removal (Scion xB 04-06) Similar Process for the xB2
Originally Posted by dannyk9260
Has anyone done a rear wiper delete
Here is my DIY Tech: Rear Wiper, Removal (Scion xB 04-06)
from 2008 w/photos Step by Step. Similar Process for the xB2.
MR_LUV
19Geezer38
Jan 25, 2017 05:08 AM
SuBSiN
Scion tC 2G Aero & Exterior
Aug 31, 2013 10:34 AM
homestretch123
Scion xD Aero & Exterior
Mar 15, 2013 02:49 AM
Team_Gileto
Jun 22, 2010 03:53 PM
Jnd9680
29
Feb 16, 2007 08:05 PM
