Canister valve..
Canister valve..
Hey guys whats up, I have a 2013 and I have been trying to diagnose my EVAP codes
P0455 - EVAP System Leak Detected (large leak)
P0441 - EVAP System Incorrect Purge Flow
Yes I already changed the gascap, same thing comes back.
I have done a ton of reading and today I even took out my intake solenoid and tested that with a 12v source and it seems to function properly.
I was next thinking the problem is the canister valve.
I have been trying to find the canister valve online just to have a look, but what I am thinking is that it is built into the actual canister and it's not a separate part.
Maybe I'll just take off the whole canister and see what I can understand about it with this valve.
And If I need a new canister because of this valve (just because I'm thinking the actual canister usually isn't the problem) I will find one on eBay or a local junk yard.
Any tips is testing my canister/valve would be great appreciated!
Thanks so much!
______________________________
Thanks so much!
Last edited by MR_LUV; 08-29-2019 at 12:58 AM. Reason: Moved to Correct Forum by Administrator
Is this what you tested with the 12 volt source?
https://www.ebay.com/itm/Vapor-Canis...QAAOSwukVbIJWS
Yep exactly.
I know I should probably do pressurized test to fully conclude that it's functional and I probably will do that next.
I did the hack way of blowing into it and sucking and I got literally nothing.
Thank you so much for manual and I'm about to look over it.
I know the 1st Gen does actually have a valve that has a part number and it is separate from the actual canister, but there is no such part number for the 2nd Gen that I have seen.
I need to just take the thing off tomorrow and see what's up with it and why the valve is how it is, where ever it is.
I will update this thread to help others who find it from Google.
____
____
yep it would click when I applied the 12v source, could not blow through it until I applied the 12v source.
I did a smoke test with a cigar and find smoke coming out of the gas cap on both the new cap and the oem cap, about the same amount of smoke.
I'm going to start a new thread maybe I can figure out how to fix the problem. The car was in accident drivers side rear before I bought it I will post pics with a good title.
Are you getting 12V from the wiring harness connector with ignition on? If no, check the wiring for rat nibbles.
How about corrosion on the contacts... try giving the socket (female side) a short squirt of WD40 and plugging the connector in a couple of times to wipe the corrosion off
Never know, it might just work
Just read your other post - can probably ignore this suggestion
Dman179
07-11-2015 11:57 PM
