Low oil levels
Exactly my point! If the tolerances are larger then the engine will use oil. If the parts are "defective" things will get worse in a hurry and continue escilating downward until the engine/car needs to be replaced. And if these tolerances didn't fall into the quality assurance inspector why did these engines leave the factory?
I thought that the days of machining engine part using CNC machines took out the varibles of, it's good enough, let's go home for the day!
The fix is the piston/piston ring assembly. I think it's an engineering issue, you think it's a QC issue. In the end, the result and fix are still the same.
Sounds like a quality issue with their engineers!
The results are the same, yes! Crappy cars are being built and people are not happy with Scions!
Until Scion tells us why there is a problem we wil never know why the problem occured.
If Scion really reads on line posts I'm sure they will want to clear this issue up soon or go the way of General Motors!
As irritating as it is, there are tons of problems with new cars all over the place, not just Scions anyway. Cost cutting is the reason for this, and with how complicated new cars are getting, it's going to be harder for them to judge how much costs to cut.
I agree, Scions have tons of problems, and that's only mine!! lol
Don't know about the cost cutting effecting my problem, but at just over 63k it burns oil, needs a new rear wheel bearing, water pump and ignitions coils have been replace also.
I will still have to try a heavier oil soon and hope it makes it to 100k without Al Gore knocking at my door or not passing state inspection.
The catch to that TSB is you have to be under 60k and use more than 1 qt. in 1200 miles.
I'm at 63k and use about 1 qt. every 3k miles, I too use Mobile 1, 5w-20. I'm going to use 5w-30 next time and see if that helps slow the oil usage some.
Had my ignition coils taken care of yesterday with that recall.
Not too impressed with Scion's quality and the way they are handling this oil usage due to bad piston/rings.
Did you have to get towed to the dealer to have all 4 defective coils replaced? Odd that they all went bad at once. Certainly Scion didn't replace all 4 coils at 63k miles simply because they might fail?
I don't mean to single you out but I'm increasingly annoyed by all the complaints of poor Scion quality and service because someone's XB has some squeeks and rattles at 50k miles that the dealer won't fix for free or the recent Toyota-BBQ over imbecile drivers stomping on the gas pedal instead of the brake and then crying about how their Toyota accelerated out of control.
If you want Rolls Royce quality and service, buy a RR... although they still burn some oil and can't read your mind to determine that when you floor the gas pedal you meant to hit the brake instead...
Again, this is not directed entirely towards you. More of a genreral rant against perfectionists with inflated expectations and value meal budgets.
First new car? Expected Lexus quality and service for econobox prices? Expect Scion to replace pistons and rings in every XB2 because they may consume more oil than you think they should? I assume that you've already replaced your PCV valve in order to conclude that your slightly high oil consumption rate is caused by "defective" pistons and rings.
To add to this post, a lot of complaints simply come from people who don't know any better (whether it is how to maintain their car or just mechanics/car stuff in general) and just blindly follow another person's complaint. People need to stop getting mad that their parts don't last 500,000 miles.
Hope someone never needs a answer to their problem because this site sounds like a cheering section for Scion cars!
This isn't my first new econo box, just the only one in 40 years of buying cars that I've had such poor quality!
It's Scion that changed the oil consumption from 1 qt per 600 miles to 1 qt. per 1200 miles. If a person follows their manual (1. qt per 600 miles) why would a person take their car into Scion and complain, its' normal according to the owners manual. However, now it's not normal to use 1 qt. of oil in less than 1200 miles according to the TSB for bad piston rings! So, how is a person to know they have a problem if Scion doesn't send out the information on the new TSB to the owners of these cars? I can't read their minds, can you?
As far as the coils failing, they never failed on my car, and yes, Scion replaced all four just for the fun of it I guess!
This is typical, if the problem hasn't happened to some people then it doesn't exist! Just because your coils haven't failed (neither did mine) I guess Scion is wrong when they said that there is a problem with these coils and they should be replaced!
Did that person take pictures of the imbecile that stomped on the gas instead of the brake? Was he inside this vehicle at the time? If he wasn't there to see exactly what happened, how does he know?
Don't take this to heart, just wanted to point this out!
As for the piston assembly TSB, I'm not sure what you're complaining about. Is it the fact that Scion changed the excessive oil consumption threshold from 1qt/600 miles to 1qt/1200 miles? I initially thought that you were upset that your XB is consuming 1qt every 3k miles. Which is it?
As for the coil packs, obviously Scion determined that their failure rate exceeded their standards and decided to offer free replacements via TSB. I don't understand why you're complaining about this.
As for the ridiculous claims of Toyotas suddenly accelerating out of control, this is nothing new. It happens all the time with all cars. The first time I remember the media getting their sensationalistic yellow claws into it was with the Audi 5000 back in 1986. It was front page news everywhere and even 60 minutes specially modified an Audi 5000 to grab some rating share. The final investigative conclusion from the NHTSA that every reported case was caused by driver error was lucky to see page 20. Fast forward to 2011 and repeat.
SUA facts:
There are only 3 known causes:
1) Sticking pedal, linkage or throttle plate (no electronic causes known)
2) Floor mat interference
3) Driver error (applying throttle instead of brake)
It's important to note that in causes 1 & 2, vehicle movement can still be stopped by applying the brake even at WOT. Therefore I stand by my assertion that every single case of SUA was, is and always will be the direct result of driver error despite the potential for other contributory factors.
BTW, I've never really liked Toyota or Scion. I've always felt that Toyota makes the blandest, most boring cars on the market. I only bought my XB because it happened to meet my needs at the moment I was looking for a new car and it's quirky styling and practicality appealed to me.
Originally Posted by xbscion
I've read the posts in this "Low Oil Level" and I would never say that any of these people fit your description. They want to know if others use as much oil as them! Can't say they are stupid or self serving, it's Scion that admitted to having the problem with their engines. I remember when Toyota starting to deny claims for sludge in their engines, said it was poor maintenance (even the people that had receipts of proper maintenance), then reversed their decision and fixed the problem people had.
You might question why I'm saying the things I do. I am not a Toyota/Scion fanboy or anything like that. The new Toyotas are boring as hell, and Scions aren't exactly the ideal platform for fun. I'm just someone who's used to working on cars and I'm mechanically knowledgable enough to be fine with whatever happens. I also have an engineering background so I know a thing or two about some of these problems/things. My MK3 Supra was plagued with stuff that was and wasn't my fault (head gasket, etc.) and it just taught me a lot about proper maintenance (they were very sensitive with oil too....).
This TSB problem will cost Toyota a bundle to fix, the longer they hold off the fewer vehicles still remaining on the road to be fixed. Looks like a business decision to me!
We aren't talking about squeeks here, we are talking about the heart of a vehicle, the engine . That isn't a inexpensive problem that any car owner should have to shoulder because of Scion's build quality.
Wait until the lawyers get involved, then Toyota will wish that they would have spent the money fixing the engines in these cars now and not later.
Toyota/Scion have already taken care of the potential oil consumption issue via TSB. Are you suggesting that they recall every 2AZ-FE engine (regardless of oil consumption rate) and replace the pistons and rings? Seriously???
Good luck with your lawyer dude, I have a feeling you'll get along great.
This is my first Toyota, and I guess I'm not clued into how I should evaluate their TSBs and recalls Vs my previous experience. I guess I expect the power-plant to be long lasting, but I have little sense of what that translates into relative to other vehicles. I very much like my xB2, but it's clear it's best I keep my eyes open and be ready to react if something comes up. Is my much earlier car a better quality machine for the money? Maybe (though features are different), but I'm not sure, and the combination of features and capability of my current car is pretty darned impressive (despite it's ultimate imperfection).
Perhaps it's a question of what we compare against?
Well, you already got the answer. Replace the piston/piston rings, use heavier weight oil, PCV valve. Good luck, and sorry to hear this is happening to your car. It does suck, but there's not much you can do other than jump ship (trade car in) or fix it yourself. I doubt it'll happen within the warranty period (although I'm sure you're past it now, right?)
Wow, so many questions!!
First of all my profile was never completed, people like to judge people by what they read! I'm 61 years old and have been buying news cars since I was 20 years old.
My first new car was a 1971 VW for Less than 2 grand, a cheap econo box that ran over 200k with the origional clutch and never touched the engine. I guess that is too much to ask for today with all of the automation, and reducing the chance for human error from human machinests.
I'm concerned about this oil consumption because it's getting worse every oil change. The fact that I use 1 qt. every 3k now, when I hardly used any when new is a upward trend. The statement as to what's the big deal about Scions recommended oil usage changing from 1 qt. every 600 miles being normal, to 1 qt. every 1200 miles is now a problem is because they moved the goal post up to 1200 miles! Think about what they said! If you have a oil consumption of 1 qt. every 600 miles no problem, this is normal! Every 1200 miles same amount of oil used, you have a problem that we will fix under warranty!!! Big of them! So how do you know if you have a problem or a normal situation? Remember, 1 qt of oil every 600 miles WAS normal for their engine, now it's not!!!! So when they have a Scion using 1 qt. every 1200 miles under warranty they have a bad engine? How? 600 miles was consider normal and still is for some engines without the piston problem. Double talk!
My comment about sludge was an example of how Toyota handled this problem when it came out, I belive it was their vans engine around 2002. It probably wasn't our engine, the fact of the matter is how they dragged their feet until it came to the attention of the media, then things changed. Should never have come to that in the first place.
If you don't know the answer to the question please do us a favor, move on!!!!! Don't need to hear how wonderful your xB's is since you aren't experiencing this problem.
I'm still very curious to hear more specifics about the quality issues you've had with your XB that lead you to declare it the poorest quality car you've owned in 40 years. According to J.D. Powers the XB2 is the best in it's class for reliability (5 stars). I think that instead of bashing Toyota and Scion for what you perceive as poor quality on a forum full of satisfied owners, you should focus more on why you're having so many problems with your Scion while others are not.
Using 1 qt of oil every 600 miles is not normal regardless of what you read or heard. Using 1 qt every 1200 miles is still excessive, IMO. Still, if Toyota/Scion did change the threshold from 600 to 1200 miles they did us all a favor and I still don't understand how you think this is a bad thing.
As for the alleged sludge issue, didn't it occur to you that Toyota probably took some responsibility solely to appease people like yourself who actualy believe that a well maintained engine can create sludge build up by itself? Why do you think that Toyota recalled 8 million vehicles in 08 & 09 due to SUA claims even though they already knew that there was nothing wrong with them? Audi lost billions of dollars due to bogus SUA claims in the 80's and although eventually vindicated, they were then sued by litigious scum bags because their Audi's resale value had been reduced. Why do I even need to explain such elemental concepts?
Anyway, the answers are to change your possibly sticking PCV valve, switch to 0w30 or 5w30, use only high quality oil and filters, change them every 5000 miles and keep your unsolicited life advice to yourself. If your oil consumption ever increases to 1 qt every 1200 miles, contact your dealer for TSB repairs and/or trade your "poor quality" Scion in for another '71 Beetle.
DAM626a Thanks for the link, the more people that know about this oil consumption problem the better chance of getting Scion to fix it. Looks like it affects not only TC/xB's but the Toyota line with the same engine. Very helpful, thanks!
Oil "disappearing"
I have a 2009 Scion XB. I have it serviced when required at the dealer where I purchased the car. The car has approx 58,000 and recently the oil light flashed. I took it to Toyota and it was 3 qts low. (I had service and an oil change about 3,000 miles ago). The dealer said they can't find a leak, drive it another 1,000 miles and come back for them to re-check. I have been checking it myself and noticed the reading on the dip stick getting lower. If there is no leak, and no smoke coming out of the exhaust, WHAT IS HAPPENING TO THE OIL??
blmingione, it sounds like you have bad parts per the TSB Toyota put out a while back. Just dump the car and move on like a lot of xB owners have. People here that haven't had this problem will come to the defense of their xB and tell you that no car is perfect, but this will not help your oil consumption problem.
Really, you probably have bad piston/ring installed when new and it looks like you are at the mileage that it shows up. My xB was doing the same thing as yours so I dumped it while it still had some value.
Good luck!
Good luck!
OIL LEAKS
Just want everyone to know I both contacted my Dealer AND called Toyota HQ in CA regarding the factory defective pistons and pistons rings in my 2009 Scion causing excessive usage of oil. THEY REFUSE TO DO ANYTHING because my car is a few months past warranty.
I owned a Chevy in 1972 that blew a head gasket. Although it was out of warranty, Chevy paid half the bill for repair. I owned a Land Rover Freelander and in 2008 the engine "blew". Again the car was out of warranty. LandRover offered to pay half the expense.
TOYOTA WILL DO NOTHING. This is POOR customer service. This is the LAST Toyota I will ever own and I will discourage everyone I know not to purchase one either!
awdmofo
02-08-2016 05:58 AM
Boomshaker
06-28-2015 02:37 AM
my06tc
06-25-2015 12:18 AM
cid_mcdp
01-05-2015 02:45 PM
