No start, no crank with humming/buzzing sound
Old Jul 19, 2019 | 05:59 AM
rickyb's Avatar
Default No start, no crank with humming/buzzing sound
I’ve been having this issue with my 2008 Scion xB, which is the no start, no crank with a humming/buzzing sound. I bench test the starter vs the new starter and the new starter was stronger, so I replaced the starter and I still had the same problem. So, I did a little more research about testing the wires and found out that I have a bad ground somewhere. So, my quick fix was to ground the starter directly to the battery and it started right up. I will order some ground wires and replaced them all in the near future, but for now I’m happy it’s running again. I hope this helps those with the same issues.
Old Jul 19, 2019 | 06:15 PM
Greg S's Avatar
The bad ground is almost always the main engine ground directly under then air box. You'll need to remove the air box and battery to get to it.
Jordly221
Feb 13, 2019 05:29 PM
Booshy08xb
Oct 23, 2017 06:21 PM
victor123897
Apr 20, 2013 10:36 PM
gp1817
9
Sep 1, 2011 01:00 AM
rvitito
Sep 16, 2010 02:46 AM
