Only hearing a Click when Starting..
Old Nov 3, 2020 | 06:09 AM
Nosoupfuru's Avatar
Default Only hearing a Click when Starting..
When I go to turn over my car I only hear a single click, doesn’t always happen however it has been sitting for a few months due to not being able to fix the suspension issue. I have four fifteen inch subwoofers and two batteries with double zero gauge wire.
All my lights turn on and so will the system so I don’t think it’s the battery. I feel like it’s a starter but don’t know for sure, I have also had an idling issue at stops. And am sure it’s related to the subwoofers but am not sure on what it is.
Throttle body, fuel lines clogged or even file pump maybe?
If anyone has any ideas on either of these issues let me know it’s been struggling for awhile but only has 87k miles on it.
____
Old Nov 3, 2020 | 06:07 PM
Greg S's Avatar
Check your battery to chassis and engine to chassis grounds. Specifically where they connect to the chassis under the stock air box. Also check your battery voltage. If it's below 11 volts you'll still have enough power to turn everything on but it probably drops to low when trying to start. I would hope that with all those speakers and amps that you upgraded your alternator and did the big three upgrade for the engine power wires. If not you should seriously consider doing it.
Old Nov 3, 2020 | 06:50 PM
drizzoh's Avatar
Battery is dead.
It requires significantly less amperage to power lights and speakers than it does to start an engine. The voltage might be fine but the CCA's are toast. Can try a trickle charger but it might be too far gone from sitting so long. I'd have it tested.
Old Nov 3, 2020 | 06:53 PM
Nosoupfuru's Avatar
I have put a 250 amp alternator and 00 gauge wires to run the electrical connections
Old Nov 3, 2020 | 09:06 PM
Nosoupfuru's Avatar
Originally Posted by drizzoh
Battery is dead.
it’s weird though cause it starts sometimes and other times no
Old Nov 3, 2020 | 09:28 PM
drizzoh's Avatar
You said it had been sitting a few months. Batteries don't like to just sit, even if there are multiple. If it's been sitting and still starts sometimes, there has to be a loose connection somewhere. :/
Old Nov 4, 2020 | 04:04 PM
RichBinAZ's Avatar
Min voltage for a lead acid is 12.3V - sitting overnight
Good battery is 12.9V
Autozone will do a free check - if you can get it started.
Old Nov 4, 2020 | 05:15 PM
Greg S's Avatar
Also a stupid one but check that the nut on the start is tight. I had this issue on and off for a month before I finally checked this and discovered it wasn't fully tight.
CXTKRS1
Scion xD Drivetrain & Power
Apr 26, 2013 07:14 PM
tim156
May 7, 2012 01:43 AM
gp1817
9
Sep 1, 2011 01:00 AM
tCduck
10
Sep 6, 2007 05:32 PM
