P0301 code
Old May 25, 2018 | 01:36 AM
Xbox69's Avatar
Default P0301 code
I have been trying to get this code to go away. My VSC Light off blinks and Check Engine Light will also blinks. I finally got this code. I have swapped coil packs from 1 to 2. And I have replaced all 4 plugs with new NFL. There was a bunch of gunk on Cyl 1 plug.
All four were whitish. I have 193k miles. It uses oil quite a bit between oil changes. I also dumped a bottle of Seafoam in the tank at a half tank and let it run for about a hour. Hoping it would help clean out the injectors. I'm dreading buying a new injector
because they run $137. It will hesitate when giving throttle some times. But at idle and light throttle it's smooth. Help.
Last edited by MR_LUV; May 26, 2018 at 01:46 PM. Reason: Moved to Correct Forum by Moderator
Old May 25, 2018 | 07:14 PM
Greg S's Avatar
You've tested the usual stuff. Next step is injectors. Maybe try swapping 1 & 2 to see if it moves. Also did you clear the ECU after you swapped the coils to make sure it was reading a new code?
Old May 26, 2018 | 12:38 AM
Xbox69's Avatar
yep cleared the code. Well I will swap the injectors this weekend. Thank you
Old May 26, 2018 | 10:56 AM
kidd's Avatar
I tried several apps on my phone. Toyosys free finally gave me the right code for an O2 sensor. At 193k you could have another one go bad.
Use Top Tier gasoline
Epix20
Jan 3, 2013 11:42 PM
DjDannyXL
18
Oct 14, 2012 12:40 AM
maple
Jul 4, 2012 07:57 PM
thaotc
11
Feb 3, 2009 01:36 AM
Dwatts5250
Toyota Camry 4th-Gen
Nov 6, 2008 01:59 AM
