TurboToyotas "where is my $h!t"
Alright bolted everything on including the cx-racing 3" exhaust. I gotta drop the car back off at the exhaust shop to get the exhaust fixed to mate to the dp. As for the cx-racing exhaust fitment is a bit rough could use extra hanger in the rear to keep the shaking down also muffler tip rubs on the rear bumper a bit. Waiting on camera to charge to take pics. Hopefully everything works out and I can finally go get a profesional tune.
Looks good. i had some of the same issues. i bought a new radiator house. not exactly the one for the car but i used it to move the hose away from the turbo. i also have a little bit of a different setup. also you should remove that piece from the crx exhaust. that piece is only in there if you want to run the silencer. just an fyi. your setup looks great though.
Alright my B is at the exhaust shop wont get here back till tomorrow. As for the silencer yeah I will pull it off. I dont see the exhuast being crazy loud for it. Cant wait to get tuned I could feel the difference just with the new manifold the turbo was spooling much quicker. Hopefully all this works out I can concentrate on the body and new shoes.
I might try e85 on my rotary got big plans for that, just not the funds right know.
explain how you modify it to work there is no way unless you run a return set up walbros dont fit our cars we have a diff set up but hey
guess what i did tonight
went 12.8 in the 1/4 who says bs cant be fast lol
Decided to go sleeper with the grill re-installed.
Also I was doing some tuning and this is what I got. Btw full 3" exhaust.
I have been having issues with stalling and surge along with my afr going from 10 to 17 back to 14.7 after getting off the gas. I looked for boost leaks and could not find any, I've gotta have a vacum leak somewhere.
I was thinking it might be the pos greddy bov. Oh and the smoke was cuase instead of pulling fuel I added a ____ load by not putting a - when I set my values in my map. I having even gone back and found that I some times put in letters or 0s by mistake so double check ur maps when you make changes.
From the picture it looks like the MAF is before the BOV? if thats so, thats the reason that my setup was changed to a blow thru setup. now my maf is on the charge pipe and the bov is right after the inner cooler. not 100% on that but i am pretty sure.
I have always had this issue. I even tried to change injector response time which did keep it from stalling but I still got the surge and like a delay when I hit the gas and let off. It either the injectors or bov.
Another thing is that I keep going rich as soon as I tap the gas pedal no matter what changes I make to my tune, I go 10 to 17 then back to 14.7 which leads me to think it is a leak somewhere. Under boost she holds up solid to 12.1 to 11.9 but out of boost drivability is like poop. I gotta find the leak as it is fouling the ____ out of my plugs.
send me the map your trying to use and i will take a look at it if you want fastbug2276@aol.com is the addy and hmmm i dont have any of thouse problems you want me to send you some of my maps and see if any of them work better for you?
Hey Cory I just emailed you my map. Worst come to worst I will just put the stock injectors back in and use a zeroed map. That way I will know it is not the injectors that would only leave the bov.
I gotta tear this thing apart becuase it is untunable like this.
