TurboToyotas "where is my $h!t"
Originally Posted by NoLimitzInd
you need to check the xD forums. Todd has let another person down over there. He had the guys car for 3 months + and ended up giving the car back not done and no money. Not a good business adventure there to me.
Great guess that new manifold may never come.
Well I've played with the tuning got the idle afr and the stalling fixed. I zeroed out some of my o2 map and after trying and compareing some tunes I began to make adjustments in the Ignition and fuel maps. SO far so good a bit too rich though as I get a cel.
As for my manifold I was planing on getting it re-surfaced there is a machine shop up the street. The exhaust leak is not that bad, The Rtv is holding up well I cant feel the leak but you can see a bit of carbon out the bottom left corner. I'll post a vid tomorrow.
Originally Posted by TurboToyotas
Pedro-
thanks for the kind words sir!
Rest is shipping tomorrow so you will be boosted this month, or at least have all the parts to be boosted.
What size wheels you rolling on?
And if possible I would like to have a bunch of high res picts of your ride..inside, outside, turbo kit etc please.
Regards-
Todd
Regards-
Todd
My $1200 Ebay CXR turbo kit shipped in 2 days and arrived in 5 days from the other coast. Kit had wrong size DP flange and took another 5 days for a replacement DP that fit perfectly. Entire kit bolted up perfectly except for MAF flange which required some modification. Manifold fit perfectly but I felt it needed some dremel work on the inside runners. The SMIC came with custom mounting brackets that fit perfectly and kit had all necessary hardware (except an air filter) included.
$3000 TT simple kits are hit and miss, if and when you ever get one. The basic $3500 Descendant kit uses the stock airbox and hose clamps instead of t-bolt clamps. Treadstone/Ancla basic kits cost $4000 and no one has been brave enough yet...
I'm so happy I didn't listen to all the advice I got before ordering my "____ty ebay turbo kit".
Toyota should sue them to force them to remove Toyota from their name because it seems to imply that they are backed by Toyota, when it is blatantly obvious from their lack of customer service that they are not.
i was considering cx, tt and ancla and im going with ancla. ive already put my order we'll see how it works out and i got it at a good price because hes sponsering me in GA. First xb over here to do it. we will see how it works
Fack some how I managed to get my map to lean out to 15 in boost and idle rich at 13.3-to 14.3. I'm trying to get some logs off my scanner. My last long term fuel trim was at -35 short term all over the place while driving and-6 to -3 at idle.
Good luck and congrats.
Originally Posted by tainoxl
flip some how I managed to get my map to lean out to 15 in boost and idle rich at 13.3-to 14.3. I'm trying to get some logs off my scanner. My last long term fuel trim was at -35 short term all over the place while driving and-6 to -3 at idle.
I feel bad for my self,lol. Hey ScionFred yeah I'm running the 550 injectors with a basemap I tweaked a bit. My LTFT is -34. I'm still playing around with the tune. I've been doing alot of reading on efi101.com and Aem forums. See what happens.
BTW, I've been speculating that my P0101 is caused by excessive IDC trim (-20%). At -34%, do you get the P0101 code?
Good luck dude!
Hurry up Boomslang!
Yeah I get the code but only when I run my test tune. But my test tune is still pretty good I hold 11.9 to 12.2 under boost. If I could get my part throttle straight would be awsome. I'm good where I'm at I think I can leave the rest to the pros. I can send you my tune If you want to look at it.
Glad you got your tune sorted pretty well. I'd appreciate taking a look at your tune. It might just work for me too after correcting for my smaller injectors. I think my email addy is in my profile.
Word I got is that the ecu connectors can not be obtained from the manufacturer now or ever. Boomslang and others take ECU connectors from wrecked XB's and re loom to a AEM harness. So if you come across a wrecked XB pull the ECU connectors and contact Boomslang about re looming for your EMS of choice.
boomslang has tthe connectors they got them from toyota along with dezod mid agust will be when they are avalible from boomslang dont know about dezod they have the connectors just not the pins
hey scionfred i did get a price around 3300 for his kit so im going to try it with the VS and injectors cuz ive talk to some tc guys and they say it runs good and been running it for years
Anyway, I'm looking forward to hearing about your results and seeing lots of pics! Congrats and good luck!
I get the Maf code during part throttle I think. Also the rich code. Boost comes on good but during part throttle driving when I tap the gas for sec I go rich 10.9 then goes back to 14.9 to 13.9. I go on vacation this weekend so when I get back Im gonna try Verocious motorsports in Delaware for a tune.
I hope you have a great vacation and a great tune.
Quick update, just got a text from Todd yesterday with a tracking number for the parts I was missing. should be the same manifold and wastegate from the setup he posted a while back. Will be upgrading with 3"dp and full exhuast if everything is complete.
