Engine info
Old Aug 30, 2015 | 10:33 AM
Wheels1978's Avatar
Default Engine info
Hi all I have a 2014 xb scion 2.4 I was thinking about
Putting a turbo kit on would I need to lower the compression
In the motor ?
Old Aug 31, 2015 | 06:53 PM
Greg S's Avatar
Depends on how much boost you are wanting to run. The stock internals will easily handle 5-6 psi no issue. Probably a couple pounds more even. If you are wanting to go much higher then, yes, you want to change out the pistons and rods at the least probably the bearings also.
Old Sep 29, 2015 | 03:01 PM
Biggregg24's Avatar
I'd say 8 psi is about the max safe for the engine.
Old Oct 8, 2015 | 06:13 PM
TheManinDboX's Avatar
In the motor ?
Only thing is you need to have a manual, the automatic will blow up without a shift kit and transmission cooler with a turbo.
Assuming it's a manual..
The stock internals are good for 450WHP all day long..
Anything higher than that, and you should have it sleeved..
If you have the block sleeved, you can get 625WHP with the rest of the internals stock, after about the 675WHP mark, you will start to melt things, so the ceiling is really 450WHP on stock internals..
(if you want to reliably drive it)
My friend and i built his XB2 with a fully blueprinted block, and forged internals, got to the 728WHP mark before we blew the stock Manual transmission.
Which begs to ask what these people are doing to there stock manual transmissions on this forum to be having issues?
Anyway..
If it is an automatic, Buddy and I blew up a 08XB2 automatic at 220WHP, before swapping in a 5speed.
Miqmiqmiq
Apr 16, 2016 02:34 AM
annika
Mar 16, 2015 06:36 PM
NonStopTuning
Jan 20, 2015 05:20 AM
fluxingnation
Dec 26, 2014 04:28 PM
tC_Normo
Oct 22, 2003 07:20 PM
