Help with Steering wheel controls
should i go back and redo them then? with smaller taps?
does it affect the wire connectivity if i've tapped into them multiple times? im afraid my wires are gonna start lookin like swiss cheese soon
Originally Posted by jaytrey
hey guys...so after a couple of hours of pounding my head against my HU...
i got the pac to work...(holla bego)
BUT...when i went to install the HU back into place, after everything was bolted back together and pulling out of the driveway, nothing on the steering wheel worked..
it was working when everything was hanging out, but when i put it back it it didn't work...
im guessing there are two things that could have happened.
1. the wired remote plug came undone from the back of the d3.
2. all the tap-ins that i did fell apart along with resistor (praying that is not the case) because that took me a llllllooonnngggg a ss time to finish
any ideas fellas?
thanks...i am so ____ed because i spend so much time trying to get it to work...and i finally got it to work...and now it's not working again....WTF!!!!!!!
any ideas fellas?
sup..bego..thanks for your help last night...and i also figured out why it said i was in NY and arrow was pointing in the opp direction...it's because it used to be in my ford and it had adjusted itself to that car..
i went to delete all the learned routes and cra p and im back on track again...
only thing now is to figure out that damn pac...
since it was already programmed and working....if it is a plug issue...all i need to do is plug it back in right? i don't have to reprogram it
Originally Posted by bego
oh thats sick that your gps is working again!
that I am not to sure of.. if it is just plug it in and turn the key in the ignition and see how many times the light flashes for the programming mode then go from there
no problems for the help either jay
i think that it would still retain the memory...i was reading that even if you switch out the battery, it should retain the memory...
but if it is a resistor problem, i wonder if i will need to reprogram it again...
how sensitve are those things anyways?
i bought the 14-18 gauge wire taps...i think the reason the connection is so bad is because they are too big...what size taps should i get instead?
Here's a random fact, if you didn't put in the resistor, and you just wired it straight through like you did with the white interface cable, the same way you did with the red,
track up and "mode" send the SAME electrical current. The resistor changes the current of the red wire "mode" so the pac registers it as a different button. Without the resistor, its the same button. It can't tell because remember, your pac interface white wire is split in half, which it doesn't know.
ok..so i went home last night and pulled the HU out again...
the led lit up 8x which means that it's still programmed, however it was still not responding...
SO....here we go again..
im going to try to retap the wires using smaller wiretaps...22-24mm
and im going to redo the resistor and wrap it with elec tape (which i did last time)
hopefully this is the final time...it's a pain
is there any way to make sure that the resistor stays put and does not get f'd up easily?
just elec tape?
just elec tape?
instead of electrical tape, and soldering, you can always try crimping it with crimp caps
evolving_machine
Oct 21, 2023 01:16 PM
Beesh
Jan 9, 2015 06:30 PM
